Thread: rocker help
Results 1 to 20 of 21
  1. #1 rocker help
    GT Level Member BoostedComp's Avatar
    Youngstown
    installed modified 1.9s started the car and it was lightly ticking. Took it fir a drive and the ticked got worse till it pretty much stopped. But car was running bad. Thought a rocker came loose. There is white smoke from the car. Tightened all the rockers down and stared it again. No ticking but still white smoke. Any ideas or help?
  2. #2 Re: rocker help
    Charles City, IA
    white smoke where?
    SMGPFC Two Nipple General
  3. #3 Re: rocker help
    Youngstown
    sorry. From the exhaust
  4. #4 Re: rocker help
    Charles City, IA
    did you replace the valve seals? Also check for vac leaks.
  5. #5 Re: rocker help
    Youngstown
    you meam valve cover gaskets? I did those I'm about to check for vaccuume leaks. I am only seeing ten pounds vacuum compared to 20
  6. #6 Re: rocker help
    Youngstown
    also getting a flashing cel light...
  7. #7 Re: rocker help
    Youngstown
    i have the front valve cover off... will that cause a vaccumme leak? prob a newb question i know. sorry
  8. #8 Re: rocker help
    what code was the cel?
  9. #9 Re: rocker help
    Youngstown
    it was flashing... means bad missfires
  10. #10 Re: rocker help
    Banned - Busted For Scamming
    Feb 2009
    Check your plug wires... you may have one that is grounding or not on all the way
  11. #11 Re: rocker help
    Youngstown
    they were all going to the right spark plugs and were all the way on the coil packs. what would cause the white smoke? would misfires caused that?
  12. #12 Re: rocker help
    Banned
    Mansfield, Ohio
    Quote Originally Posted by BoostedComp View Post
    White smoke is coolant, do a compression test and or leakdown. Probably have a headgasket letting go or a cracked head
  13. #13 Re: rocker help
    Youngstown
    there is no coolsnt in the oil. and would that happen from just switchng rocker arms
  14. #14 Re: rocker help
    Did you take the lower intake manifold off too when you did the rockers? If so...you probably dumped a bunch of coolant into the motor...is your ICM plugged back in all the way too?
  15. #15 Re: rocker help
    HUDSON
    WHITE smoke? Could you possibly be mistakeing normal water vapor that exits from the tail pipe while engine is running (under certain condition)? Other than that, there is really nothing that would make white smoke just from changing the rockers, unless by chance you just blew a headgasket.
  16. #16 Re: rocker help
    Jan 1970
    Maquoketa, Iowa
    Did you somehow get a valve to come in contact with a piston? Either that or drop something in the engine somehow?
  17. #17 Re: rocker help
    Youngstown
    hey guys sorry for no update. it ended up being a bad rocker bolt... explination: did the front and back rockers with reusable rocker bolts. torqued down to 23ft lbs. took it for a test drive... and it sounded like a rocker tapping. the bolt wouldnt torque down the rocker to specs and keep it there so it was basically like i had a rocker off... vaccume leak, misfires, burning oil, ect all explained. got another bolt. all torqued down and runs perfect. thanks for all the help tho guys.
  18. #18 Re: rocker help
    Charles City, IA
    interesting
  19. #19 Re: rocker help
    Banned
    Mansfield, Ohio
    Did you not use Q-tips to suck up all the oil for the rocker bolt? Also I'd use a digital torque wrench over the clicky kind. Sometimes they don't click and you snap bolts off where you don't want to.
  20. #20 Re: rocker help
  1. rocker question
    By BoostedComp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 05:57 PM
  2. Rocker Arms
    By stlmo_gtp in forum PCM Tuning
    Last Post: 10-01-2009, 11:08 PM
  3. HELP! Is my rocker screwed?
    By Infinity9999 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2009, 06:50 AM
  4. rocker interchangability
    By skidoojames151 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 07:02 AM
