Thread: Belt Squeal on startup
Results 1 to 20 of 20
  1. #1 Belt Squeal on startup
    Largo, Florida, United States
    my belt squeals on startup but goes away after about 5 minutes.
    any ideas?
  2. #2 Re: Belt Squeal on startup
    Wichita
    Could be a worn belt or the power steering.
  3. #3 Re: Belt Squeal on startup
    Put soap on it
  4. #4 Re: Belt Squeal on startup
    Put soap on it
    is this a legit tip? and the belt is a gatorback belt its brand new.
  5. #5 Re: Belt Squeal on startup
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    my belt squeaked too. i discovered it was off one rib on the crank...toward the outside.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  6. #6 Re: Belt Squeal on startup
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Its not the belt, it's the pulleys. Take the belt off and use a wire brush on them. Theres residue from your old belt on them and when cold it squeeks, when hot it sticks.
  7. #7 Re: Belt Squeal on startup
    New Jersey
    Might not be the same case, but. I had a poor experience with a gatorback belt.
    I needed a new belt for my 92 chev pickup so I bought a gatorback, figured it costs more should be better.
    Belt was on for a week when I started the truck on a 95F day and turned the ac on, it squeeled and then the belt jumped off. I put it back on using a crowbar "was at work" Then noticed the idler pully was almost touching the waterpump pully. I drove home slow but the next day the belt jumped off again.
    I went and bought another Gates belt which was much stiffer and kept the idler much higher up. The gatorback was soft and stretchy.
    Due to that experience, i'll probably never buy another gatorback belt.
    If I were you, i'd go buy a Gates belt and ditch the goodyear one, your squeal will probably go away.
  8. #8 Re: Belt Squeal on startup
    Outer Space
    Cheap troubleshooting.. get a can of "belt dressing" ... not a long term fix by any means.
    02 GTP 13.6 @ 100mph - SOLD
  9. #9 Re: Belt Squeal on startup
    Las Cruces, NM
    belt dressing makes a mess, and yes, Gatorback is a gimmic. Theres actually LESS surface area on them causing them to slip more.
  10. #10 Re: Belt Squeal on startup
    Put soap on it
    worked for like 30 seconds. I'm going to try the wirebrush method
  11. #11 Re: Belt Squeal on startup
    Didn't say it was permanent...it just narrows things down if it is the help it'll tell you if thats your issue
  12. #12 Re: Belt Squeal on startup
    Ridin' the Blue IrishNation24's Avatar
    San Diego, CA
    sparty, mine does that at first, not really a squeel, but little faint chirps. i just replaced both belts, but i also need to replace my p/s pump. its leaky lol. it goes away as soon as i move.
    i didnt use gator belts tho, i dont remember which ones i used. bro got em from oriellys. 406606060 or some ****.
    http://www.grandprixforums.net/membe...lbums-car.html
    2001 GTP special edition. lots of mods.
    1994 Greenwood C4 LT1-traded in for 6700 with 160K miles for....
    a 2004 LE MANS COMMEMORATIVE EDITION Z06 23K MILES.
  13. #13 Re: Belt Squeal on startup
    lol sparty? really... >.< yeah ill try taking a wirebrush to the pulleys to see if i can clean em up
  14. #14 Re: Belt Squeal on startup
    San Diego, CA
    lol, yeah i thought it was a nice touch
  15. #15 Re: Belt Squeal on startup
    GT Level Member scoobyydooooooo's Avatar
    Houston, Texas
    Hey, I just went thru this same exact thing, Changed the serpitine belt, and all was good.
    05 GTP, Inferno Appearance package, SD Headers, 2.9 Pulley, 104 autolites, Wizaired CAI, 180* T-stat, SPO tips, Nav sytem, polymounts, S2IC, XPCAM, much more to come
  16. #16 Re: Belt Squeal on startup
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Mine does the same thing. the accessories belt is new, the SC belt is not. I'll also try the brush thing I guess.
  17. #17 Re: Belt Squeal on startup
    Minnesota
    i had squealing on mine then i replaced my ps pump and when i put everything back together it chirped really loud, double checked and the belt was off a tad on the ac pulley now its all good, just try checking everything is all lined up
  18. #18 Re: Belt Squeal on startup
    Kingsford
    Mine does that as well but it's all the time even under acceleration, put a new belt on , stopped for about a week, started back up. Changed out the Tensioner on the ACC side and still did it thought it was the alternator, still did it. Sanded down my water pump pulley and that stopped it for about a week or so, and now it's doing it again..
    Any other ideas? It stops for a few miles if i put break fluid on it, but other than that my only other idea/suggestion was to use a gator belt but now that i have read this im going to avoid that idea all together lol
    Chi_Town
  19. #19 Re: Belt Squeal on startup
    Nov 2009
    Grand haven
    I just went throught this too only on my sc belt. Check the alignment of the belt and make sure it is stright. Mine was off due to me pressing the mps hub on too far. I was on groove off on my 8 rib pulley.
  20. #20 Re: Belt Squeal on startup
    Charles City, IA
    Dont put anything on your belt. You just ruined it. Get a new good belt. I have a gator grip and it works fine on my car.
    SMGPFC Two Nipple General
  1. ARGH, The squeal!!
    By Carpepoon in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2013, 01:43 PM
  2. Brake squeal
    By 04GTPCOMPG in forum Brakes/Suspension/Chassis
    Last Post: 06-15-2009, 12:06 PM
  3. knock at startup
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:01 AM
  4. another brake squeal
    By drunknmunky in forum Brakes/Suspension/Chassis
    Last Post: 01-09-2009, 01:41 AM
  5. squeal
    By dbean in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2008, 04:22 PM
