Thread: p0443 and p0102
Results 1 to 11 of 11
  1. #1 p0443 and p0102
    Outer Space
    As many of you know, I just topswapped a L26 into my 2002 GTP.
    It cranks, however I am getting the indications of a vac leak. Boost gauge is jumping between 18-14 while it surges on idle.
    The codes I get :
    P0102 - MAF Code
    P0445 - Evap Code
    I found this thread about someone who had a similar issue. http://www.grandprixforums.net/p0443...nge-35815.html
    However, I checked all fuses under the hood and all appears to be good. Maf was not removed, nor was TB and worked fine when removed.
    So, correct me if I am wrong...the following things that could be allowing unmetered air ar as follows:
    LIM Gasket
    SC Gasket
    TB Gasket
    VAC Lines
    Evap crap
    I sprayed carb cleaner on my lines, and around the sc looking for an idle change, but couldnt find one. It's hard to listen for one when the car is surging.
    For sh1t's and giggles I unplugged the MAF while it was surging...no change.
    My plan at this point is to replace all the vac lines on top... since that will be the cheapest at this point... any ideas?
    Should I delete the evap system for troubleshooting?
    02 GTP 13.6 @ 100mph - SOLD
  2. #2 Re: p0443 and p0102
    Portland Oregon
    Psh, evap and egr just get in the way
  3. #3 Re: p0443 and p0102
    Outer Space
    Egr has been gone....but ill check my penny mod
  4. #4 Re: p0443 and p0102
    Apr 2009
    stockton ca
    evap wouldnt cause a surge or lean condition I wouldnt think
    Id just check all vac lines and make sure your egr block mods are still solid
    Ill ask at school tomorrow my smog instructor is a whiz with diag on codes
  5. #5 Re: p0443 and p0102
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Id check in this order. Maf Hz is going up as engine RPM increases and is somewhat uniform.
    Idle air counts are between 50 and 40 at a steady idle. If your surging that will not be possible.
    If theLfts are reading 16.4 or -22?
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  6. #6 Re: p0443 and p0102
    Outer Space
    Ill get scan online tomorrow ... thanks guys
  7. #7 Re: p0443 and p0102
    Outer Space
    Ok so I scanned it and it's like my MAF is dead.... not getting any HZ out of it.
    Fuse #21 ... 15amp is blowing ...so it sounds to me like a wire is pinched or broken. I have no clue where to start...and i really don't want undo and rewrap the entire wiring harness.
    Any tips?
  8. #8 Re: p0443 and p0102
    Apr 2009
    stockton ca
    start with what that fuse circuit controls shouldnt be tio bad to find
  9. #9 Re: p0443 and p0102
    Outer Space
    Due to time constraints. ( being without my DD for 3 weeks...)I'm taking it to an electrical dude near my work. I could trace it down...but saying to hell with it now...lol
  10. #10 Re: p0443 and p0102
    Apr 2009
    stockton ca
    i dont blame you man hope you get her up n running good
  11. #11 Re: p0443 and p0102
    Outer Space
    Ok, wire was pinched.... so that has been corrected. No more codes so far. I still haven't gone into boost yet. I am going to scan it on the way home today.
  1. P0443 and P0102 after spark plug change
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-16-2010, 07:58 PM
  2. P0102, p0420
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-15-2010, 12:07 AM
  3. another p0102, yes I did a search
    By GSKeith in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-21-2010, 06:45 PM
  4. P0102 problems
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2010, 07:32 AM
  5. code p0102
    By hunter_alexander in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2008, 12:09 PM
