Thread: Who is running ARP head studs???
Results 1 to 20 of 37
  1. #1 Re: Who is running ARP head studs???
    SE Level Member SlowFiero's Avatar
    Feb 2008
    Canada
    Felpro head bolts here. 3 years with felpro head gaskets without a problem. 2.6" pulley non intercooled with gen 3 blower and last year 2.8" with gen V blower both making 15 psi.
    Will be intercooled this year so hopefully beable to run the 2.55 with the genV, mabey 17 lbs????
    Billet 6262 T3 turbo, PT1001 intercooler, ST1 cam, 140 springs, pushrods, N* TB, L26 upper, HV3, otherwise stock L32. 10.007 @ 135.54with 1.46 60' 3130 lbs
    Old GenV M90, XP, heads, N* TB, ST2 intercooler - 11.425@115.60 1.54 60'
  2. #2 Re: Who is running ARP head studs???
    SE Level Member TheRealKoop's Avatar
    Lima, Oh
    I lost 4 psi when i installed my st2 IC for the record slowfiero.
    97' GTP- HAI| 160| N*| Ported Blower| 2.55"|
    S2 ZZp IC| LIM| Heads| 50#| XP| Pacesetters| Flow40's
    AL 103| S2 Volt Booster| Alt rewire| FP rewire.
    Built Tranny| Poly Mounts| 3.69's| 3000 stall.
    Walbro 255|AEM WB| Powertuner.
  1. pacesetters are way better than SLP's...when running a 4T80-E
    By turbocharged406sbc in forum Off Topic Discussion
    Last Post: 04-01-2008, 02:20 AM
  2. Studs
    By wrfdff4 in forum Tires & Wheels
    Last Post: 03-31-2008, 11:16 PM
  3. Thinking about running Drag Radials...
    By Iron Indian in forum Tires & Wheels
    Last Post: 03-27-2008, 12:13 AM
  4. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
  5. Running speaker wire....to the doors....help.
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2008, 02:14 PM
