Thread: Engine want start after intake manifold gasket replacement
Results 1 to 14 of 14
  1. #1 Engine want start after intake manifold gasket replacement
    Marysville Ohio
    Hello All,
    I have a Pontiac grand prix GTP supercharged 3800 series 2 engine
    This past weekend I had changed my intake manifold gasket because I was getting coolant mixing with the oil. So after I put everything back together the car started right up, I let it run for 15 minutes. Then I shut it off and now it's been 2 days since it was last turned on. I can't get it to start. Below I will list some things I changed, replaced, checked.
    Changed:
    Lower Intake Manifold gasket
    Supercharger gasket
    throttle body gasket
    fuel injector "o" rings
    PCV valve
    oil filter
    air filter
    oil
    coolant
    spark plug wires
    Checked:
    Fluid levels - fine
    Fuel pressure - fine
    Spark plug gap - fine
    Problems:
    -I had originally put new spark plugs in but the car wouldn't start so I put the old ones in and it started right up for the first time
    -Fuel injectors, when I was putting the fuel rail back on with the injectors I was pushing down on it to hard and the gasket at the tip by the O rings shattered. All of them did. Some of those little pieces fell into the engine but I know I got most of them out. Some still remain in the engine. To replace those gaskets I used nylon washes. It's what the put on the new injectors made today. So I went to a hardware store and bought some. Then I machined them to the correct size. I just don't know if these washers are heat resistant.
    -A vacuum line fitting ripped on me while I was taking it off. I didn't have another one to replace it with so I put it back on, put some RTV silicone on it with a pipe clamp to hold it in place.
    -I am getting the check engine light, low oil light, temperature light, and the battery light. I get these lights when I turn the key to the AUX position. I don't know if those lights always come on and stay on until the car starts but I did hook a battery charger up to the battery. Since then the starter seems to work faster. Without the charger it does not try to start as fast.
    -Some of the codes I am getting with a scanner is P0123 and P0118.
    With all of that said, I hope I provided enough information to help someone give me advice. Like I said, it won't start anymore but it started the before and ran for 15 minutes. It sounded great.
    Thanks Guys. I hope you can help.
  2. #2 Re: Engine want start after intake manifold gasket replacement
    Apr 2009
    stockton ca
    sounds like you may have a grounding issue check over all the wiring and any connectors you took off and moved
  3. #3 Re: Engine want start after intake manifold gasket replacement
    Couple things...
    1) That vacuum leak fix sounds kinda half assed and I'd get that issue addressed because it probably isn't helping the situation.
    2) 123 is the TPS...I know because I got that all the time when I first had my car. Throttle Positioning Sensor in high circuit or something like that.
    3) 118 is the coolant temp sensor...it needs replacing.
    Try those three things...also you said "some of the codes"...were there others?
  4. #4 Re: Engine want start after intake manifold gasket replacement
    Apr 2009
    stockton ca
    were any of the codes there before the repairs I guess i should have asked that
    and ofcourse the vac leak should be fixed either stealership for ome replacement or change to hard t's and rubber lines
  5. #5 Re: Engine want start after intake manifold gasket replacement
    Marysville Ohio
    Thanks for the advice. That vacuum leak fix is what it is because it happened on a sunday with no dealer. I plan to fix it. Well, I got home from work and tried to start the card and I didn't get anything. I hooked the battery charger up and it didn't start but on the 2nd try it did. I let the car run for 15 minutes, shut it off, and now it won't start again. Even with the charger hooked up.
    My other code was P1635
    The ground wires look fine and are connected properly.
    Thanks again guys.
  6. #6 Re: Engine want start after intake manifold gasket replacement
    Apr 2009
    stockton ca
    p1635 is 5 volt low ref not sure what its about though
  7. #7 Re: Engine want start after intake manifold gasket replacement
    Charles City, IA
    Check the ground behind the coil pack bracket.
    SMGPFC Two Nipple General
  8. #8 Re: Engine want start after intake manifold gasket replacement
    Marysville Ohio
    Thanks guys. Ground behind coil pack is fine. i got the battery tested and they say it's fine. i bought a new one anyway. I'm gonna try it out. I'm willing to try anything now.
  9. #9 Re: Engine want start after intake manifold gasket replacement
    Outer Space
    02 GTP 13.6 @ 100mph - SOLD
  10. #10 Re: Engine want start after intake manifold gasket replacement
    Marysville Ohio
    Here is an update.
    Yesterday I came home and tried to start the car. It wouldn't start so I put the battery charger on it and it started right up. 2 times actually. Then I took the charger off and it wouldn't do anything. So I took the battery to 2 different stores and they told me the battery is fine and fully charger. I bought a new one anyway to try it out. So, I put the new battery in and it wouldn't start. I hooked the charger up to the new battery and it started right up. I let it run for 15 minutes and then I took it for a test drive. I didn't even make it 200 feet before the car just stalled. While I was driving the car it sounded great. So, I had to get a neighbor to jump me. I hooked the cables up and the car started right up, my buddies car wasn't even on when I started the car so I don't know if that makes a difference. Once the car was started something weird happened. The RPM's went all the way up to 3,000 and stayed there. So, I got in the car then put it in reverse and the RPM's dropped to normal. Once I started driving back to my house and once I was getting close I took my foot off the break and I could feel the RPM's still way up there as if my foot was on the pedal.
    Another note I would like to mention, it doesn't matter what battery I have in the car whether it be the new or old one but the car does not try to start as fast as it does without the charger attached to it. I'm wondering if the starter is messed up, maybe the battery connections a loose or wet, the grounds are messed up, and I think the vacuum system is out of wack?
    Let me know what you think. I am posting these same questions on some internet forums and getting some responses back.
    Any idea's?
    -Dave
  11. #11 Re: Engine want start after intake manifold gasket replacement
    Sounds like the CPS to me.
    Crank Positioning Sensor
  12. #12 Re: Engine want start after intake manifold gasket replacement
    United States
    The T P S. Not working properly or the idle control valve may have taking a crap on ya
  13. #13 Re: Engine want start after intake manifold gasket replacement
    I'm thinking he won't respond this thread is 2 years old.
  14. #14 Re: Engine want start after intake manifold gasket replacement
    Out West
    its dead.
    Whine with your Cheese?
  1. Manifold Gasket Replacement... Questions
    By brownb66 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 10:54 AM
  2. Intake Manifold Gasket/seal
    By ssm90GT in forum General Tech Discussion
    Last Post: 12-12-2009, 03:06 AM
  3. Got a bad intake manifold gasket recall!! Loook!!!!!!
    By OrangeL67 in forum General Tech Discussion
    Last Post: 12-12-2009, 02:18 AM
  4. Intake manifold end cap gasket
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 07:01 PM
  5. Intake manifold gasket
    By rudyram118 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-09-2008, 09:38 PM
