Thread: How to disable my day time running lights ??
Results 1 to 20 of 24
  1. #1 How to disable my day time running lights ??
    GT Level Member bayareagtp's Avatar
    Milpitas , Ca.
    I was wondering if anyone knows how to disable their day time running lights ? Also if there are any pros and cons ? I heard it saves your bulbs so figured I would ask . thanks fellas .
    1998 GTP , 3" down pipe w/cat , u-bend delete , full 3" exhaust w/ magnaflows , no resonator , powerslot front rotors , Overkill PCM , Overkill FWI , 180* t-stat , 1* colder plugs , alt. re-wire , alt. stage 1 booster . 215 whp and 238 torque .
  2. #2 Re: How to disable my day time running lights ??
    open the side panel to your dash on the left side, and find the little black box in there, unhook the wires and bam you are done
  3. #3 Re: How to disable my day time running lights ??
    GT Level Member Preotic's Avatar
    Missoula, MT
    ^Wrong, pull the DRL fuse in the glove box. Doesn't work on some years but i know for a fact it works on 98's.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  4. #4 Re: How to disable my day time running lights ??
    SE Level Member beast3300's Avatar
    unplugging the DRL module under the driverside is the best way. If you pull the DRL fuse then your automatic lights won't work. I like the lights coming on when it's dark out. Less effort for me.
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
  5. #5 Re: How to disable my day time running lights ??
    SE Level Member GTP SE's Avatar
    Ankeny, IA
    I agree, if you just unplug the module. The light will still come on automatically at dusk.
    2001 GTP Special Edition
    |ZZP PCM|Headers|Ported LIM and blower|3.2 / 3.4 pulley|1.9's|MSD wires|Drilled 180* T stat|3" ZZP Catback l
  6. #6 Re: How to disable my day time running lights ??
    Missoula, MT
    I know when to turn my lights on. I don't need automatic lights.
  7. #7 Re: How to disable my day time running lights ??
    Milpitas , Ca.
    Quote Originally Posted by beast3300 View Post
    where abouts is this DRL module ? is it hard to find ?
  8. #8 Re: How to disable my day time running lights ??
    GT Level Member BackInBlack's Avatar
    Vermont
    Quote Originally Posted by Preotic View Post
    Part wrong as well... On some models, the DRL fuse absence will sent the BCM into incessant chiming mode. IIRC 1999 and up will have issues.
    See my web site.
    The GPs are long gone...
  9. #9 Re: How to disable my day time running lights ??
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    umm this sounds really fimilar probably because i posted about this about a month ago, but anyways what you want to do is:
    1.Open the Glove Box
    2.Remove the Panel covering the fuses(it is off to the right)(it should say "Remove For Fuses"
    3.You can look on the back of the cover for "DRL"
    4.On 97's it is the first fuse on the very bottom (going Left to Right)
    5.Pull the Fuse and Test it out
    *Hope this helps you
  10. #10 Re: How to disable my day time running lights ??
    Milpitas , Ca.
    thanks for that info .
  11. #11 Re: How to disable my day time running lights ??
    Elk Grove Village, IL
    Quote Originally Posted by BackInBlack View Post
    See my web site.
    I pulled the little "black box" from my 99 GT and it did not have any ill wanted effects. Disabled the DRLs and left the auto headlights. IIRC its 00 or 01 where this stopped working. I wanna lean towards the 01 side since thats when some decent changes happened.
    Since the OP has a 98, open the drivers side panel, remove "black box". Done. You will know what we are talking about when we say black box.
  12. #12 Re: How to disable my day time running lights ??
    Odessa, MO
    Mine's an '02. Unplugged the plug from the little box in the access hole with no ill affects, everything still works just fine, just no DRL's.
    2 cents
  13. #13 Re: How to disable my day time running lights ??
    Fort Wayne, IN
    Anyone have any tips for unhooking those wires on the driver's side? I tried for like 20 minutes last night and couldn't get the damn thing haha. There was sharp stuff all around so I got all cut up and I didn't know how to unhook them once I got ahold of them. Do you just push that blue button thing in or to the side or what?
    U-bend/ResDelete// 3.4"// MSD 8.5mm// TR6s// ZZP 1.0 PCM// 72mm TB w/ TB spacer// WizAired CAI// 180° tstat
    Best ET (stock): 14.689
    Best Trap (also stock): 93.82
  14. #14 Re: How to disable my day time running lights ??
    Vermont
    There is a wedge-tab on the BACK side of the connector as viewed through the access hole. Do NOT use a sharp object. You need to depress the tab and pull the connector out. Do not attempt to remove the blue part, as you will break the plug. I have a photo-writeup around here somewhere that shows how to take it apart...
  15. #15 Re: How to disable my day time running lights ??
    Ankeny, IA
    Quote Originally Posted by Abrasive View Post
    2 cents
    Same as my 01
  16. #16 Re: How to disable my day time running lights ??
    SE Level Member Duke1822's Avatar
    Toledo,OH
    i have an 02 and i was trying to push the blue part too and got all cut up haha
    But when i pulled the DRL Fuse i could here this high speed clicking nere the lower left of the dash when i put the fuse back in no more noise? but im going to try to unplug the black box and see how that works
    02 GP GT 40,000 mi Stock For Now
    87 Firebrid Formula 65,000 mi
  17. #17 Re: How to disable my day time running lights ??
    ^^^im getting the noise too...im working on getting rid of that now...look for a write up
  18. #18 Re: How to disable my day time running lights ??
    Toledo,OH
    pulled the connector on the black box and no more DRL's yay and still have my auto lights so thats worth the cuts haha oh and no clicking i read that thats the BCM not liking what your doing i think it does that because its not getting reference voltage? but if you pull the black box and leave the fuse it will not click so i just left the DRL fuse in everythings good so far
  19. #19 Re: How to disable my day time running lights ??
    Donating Users r33na's Avatar
    wi
    i have a 2k...and im going to try what i read...as far as the "black box" goes..the info on this site is great..thanks to evryone who wrote about this!!!
    2k8 PONTiAC GRAND PRiX
  20. #20 Re: How to disable my day time running lights ??
    wi
    ok ...i went and looked...is this black box the one with the three wires..i think one is purple? and its super hard to get out?
  1. disable lockup 1999 regal gs
    By smokingjoe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2010, 10:35 AM
  2. pacesetters are way better than SLP's...when running a 4T80-E
    By turbocharged406sbc in forum Off Topic Discussion
    Last Post: 04-01-2008, 02:20 AM
  3. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
  4. What brand/style of tires are you running?
    By John02Hawk in forum Tires & Wheels
    Last Post: 02-15-2008, 01:18 AM
  5. Brights & fog lights at the same time...
    By kabobulate in forum General Tech Discussion
    Last Post: 01-16-2008, 10:29 PM
