Thread: supercharger find
Results 1 to 19 of 19
  1. #1 supercharger find
    Donating Users Warbeaver's Avatar
    St. Louis
    what 3.8 does this go on?
    GM 3.8 Supercharger
  2. #2 Re: supercharger find
    Dec 2008
    michigan
    M62 (3800 Series 1 L67)
  3. #3 Re: supercharger find
    Banned - Busted For Scamming
    Feb 2009
    m62, was used on the series 1 3800's
  4. #4 Re: supercharger find
    St. Louis
    why does it resemble the genV so much?
  5. #5 Re: supercharger find
    Feb 2009
    trust me, it doesnt.
  6. #6 Re: supercharger find
    ^^That.
    They were horrid blowers that required sub 2.8" pulleys from the factory to make power. They tossed those on the LSJ's and I guess it worked...but there was a ton of work done to them too before they reused them over 10 years later.
  7. #7 Re: supercharger find
    St. Louis Mo.
    Its for the Bonneville SSEi. It will not work on GPs.
    James Shafer
    St. Louis MO
  8. #8 Re: supercharger find
    Quote Originally Posted by GeddyLee View Post
    And the Rivvy, the Park Ave...basically anything with a pregen supercharged 3800 Series I...
    Pulled from Wiki...
    L67 Supercharged
    The Series I Supercharged engine went through many internal changes and the horsepower changed rapidly between the time it was introduced and the time that the Series II L67 was introduced. The M62 supercharger was manufactured by Eaton, exclusively for the GM 3800 engine. HP was rated at 205 for 1991-1993 engines (models vary), and 225 for 1994-1995 engines. The additional horsepower and strength was gained by using six bolt main bearing caps, a roller camshaft, semi forged bottom end, larger throttle body, roller rockers and epoxy coated supercharger rotors, improving efficiency. The 1994-1995 utilized a 2.85-inch (72.4 mm) pulley versus the 2.55-inch (64.8 mm) pulley used on the 91-93 supercharger.
    Applications:
    1991-1995:
    * Buick Park Avenue Ultra
    1992-1995:
    * Oldsmobile Eighty-Eight LS, LSS
    * Oldsmobile Ninety-Eight
    * Pontiac Bonneville SLE, SSE & SSEi
    1995 Only:
    * Buick Riviera
  9. #9 Re: supercharger find
    St. Louis Mo.
    ^^^^ And those too
    James Shafer
    St. Louis MO
  10. #10 Re: supercharger find
    Peeeyaaaaah!
  11. #11 Re: supercharger find
    St. Louis Mo.
    Moved to correct section.
    James Shafer
    St. Louis MO
  12. #12 Re: supercharger find
    been in a 95 ultra, not necessarily a slow boat.
    Also consider the M62 used now is a Gen V blower, not a pre gen III or whatever was put on the car back then.
  13. #13 Re: supercharger find
    Nope. The Cobalt/Ion supercharger is an M62 with an extended snout/intake side pre-rotor.
  14. #14 Re: supercharger find
    Really?
    There IS a gen V M62 though: http://www.eaton.com/ecm/groups/publ.../ct_128484.gif
  15. #15 Re: supercharger find
    Feb 2009
    Yea they have the usual changes like the different intake design, better outlet, and the abradable coated rotors. They are not the same as the old ones. The only thing they share is flow rate.
  16. #16 Re: supercharger find
    does that thing even have power steering?
  17. #17 Re: supercharger find
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Doesn't look like it. Might go toward the back though.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  18. #18 Re: supercharger find
    Delaware, OH
    yes it's an electronic assist power steering.
    No More GTP for me.
    2014 Chevy Cruze ECO Manual. 40+MPG
  19. #19 Re: supercharger find
    I see... that must be one massive alternator then.
  1. cant find please help
    By kjohnson in forum Audio, Security & Visual Electronics
    Last Post: 05-26-2009, 12:33 PM
  2. Those anybody now where to find ???
    By Whitehispanic in forum Visual/Body Modifications
    Last Post: 03-25-2009, 07:41 PM
  3. Where to find..?
    By Nickell in forum Visual/Body Modifications
    Last Post: 01-20-2009, 04:25 PM
