Thread: Stuttering top of 2nd gear
Results 1 to 9 of 9
  1. #1 Stuttering top of 2nd gear
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    Since i put in the Overkill pcm about 3 weeks ago, my car kind of stutters right before 2-3 shift only from 5.5-6k rpm (yellow area) pulls fine up until that point. Also 1st gear pulls fine until 6000 and shifts fine there, problem is only with 2nd. Before the pcm, the car obv shifted at 5.5k so i don't know if the problem would have happened before pcm install or not. Any ideas?
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  2. #2 Re: Stuttering top of 2nd gear
    SES light?
  3. #3 Re: Stuttering top of 2nd gear
    Dec 2008
    London, Ontario
    no nothing at all...i dont know what it is. But will is a member of a local board and said he would reflash the pcm for free, so hopefully that will fix it.
  4. #4 Re: Stuttering top of 2nd gear
    New Jersey
    Quote Originally Posted by Rather B Blown View Post
    Are you running a stock pulley?
  5. #5 Re: Stuttering top of 2nd gear
    Outer Space
    Mine did that, when it was cutting off fuel (injector disable) ..before the shift. I had to change the values.
    02 GTP 13.6 @ 100mph - SOLD
  6. #6 Re: Stuttering top of 2nd gear
    Dec 2008
    London, Ontario
    Quote Originally Posted by 00RegalGS View Post
    yep stock pulley until i put on my 3.4 next week
  7. #7 Re: Stuttering top of 2nd gear
    Dec 2008
    London, Ontario
    Quote Originally Posted by Lawngoose View Post
    yeah it does feel like its leaning out and slightly misfiring at the same time. Hopefully the reflash im going to get Will to do will fix it
  8. #8 Re: Stuttering top of 2nd gear
    Jul 2008
    sumter,south carolina
    if its tuned for a 3.4 u should have done pulley and PCM at same time... i would put pulley on before i go reflashing things.
    02 GTP with mods 05 GP for DD
  9. #9 Re: Stuttering top of 2nd gear
    Outer Space
    get a scan of it happening and look at injector PW, if its 0 .. your injectors are cutting off (which is bad) .. and you should see some KR too.
  1. stuttering?
    By nyydmb12 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2010, 08:10 AM
  2. stuttering at high rpm
    By DOUGLASMELTER in forum General Tech Discussion
    Last Post: 05-18-2009, 05:02 PM
  3. Stuttering?
    By Southern Yankee in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-21-2009, 09:20 PM
  4. Stuttering... Chugging?!?
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-22-2008, 06:53 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
