Thread: p0243 code
Results 1 to 2 of 2
  1. #1 p0243 code
    SE Level Member IllegalIntentions's Avatar
    California
    Boost solenoid is throwing a code. Anyone ever have this issue? I have done some reading and it can be a variety of things from a ground, pcm, to a bad solenoid. Just looking to get a head start on this with any first hand info. I also hear it can be eliminated, not quite sure on how that is done though. I hear you plug off the lower hose, and leave the lower inlet open. I also hear it is not on the BBV, so what exactly am I looking for? I know where the switch is that connects near the BBV right in front of it? Also do I have to tune it out after I eliminate the solenoid, or can I leave the pcm alone since I have no tuner? Any help would be greatly appreciated.
  2. #2 Re: p0243 code
    Apr 2009
    stockton ca
    yea theres a few things you can do do a search on here Ive never had the problem but have seen a few threads on here about it
    You can check to see if its working by reving it and letting off and seeing what its doing
  1. P0243 boost solenoid
    By IllegalIntentions in forum General Tech Discussion
    Last Post: 05-09-2010, 12:54 AM
  2. maf and tps code
    By transkiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2010, 11:51 AM
  3. I got a code!!!???
    By justwhisen in forum General Tech Discussion
    Last Post: 04-14-2010, 07:22 PM
  4. P0243 and an intense shift pac????
    By Tony in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2010, 04:04 PM
  5. code...
    By gotboost3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 12:22 AM
