Thread: Plug wires
Results 1 to 7 of 7
  1. #1 Plug wires
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    So I read somewhere that I can take the dogbones of from the engine and the engine is able to tilt forward some? If so how easy is it to tilt? I put my plugs in awhile back w/o doing this and I must say, what a pain in the butt.
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: Plug wires
    Barksdale AFB, LA
    You won't really be able to do it by hand. Some put the car in park, rock the car forward, and set the parking brake when its tilted forward enough. Others use ratcheting cargo straps to do it.
    I'm hard core, so I don't even mess with it. Hell, I leave the car on the ground when I do oil changes.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Plug wires
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by Sabrewings View Post
    Sorry to get off topic, but what drain pan do you use? I might be able to get away with doing oil changes at my apartment complex if I can do it with the car on the ground.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  4. #4 Re: Plug wires
    Barksdale AFB, LA
    Just some drain pan my dad gave me. It's plastic, round, about 16" in diameter, and about 3" high.
  5. #5 Re: Plug wires
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    you must be one slim dude.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  6. #6 Re: Plug wires
    St Louis MO
    Quote Originally Posted by JCG's-GTP View Post
    I use one of these LISLE 48260 - TRANSVERSE MOUNT ENGINE TILTER GM FWD when the engine really needs to be tilted. Well worth the small amount of money. However, I dont tilt the engine to do plugs. I did tilt the engine the first time or two, but after that I became comfortable without. One thing, the first time plug wires come off, they can be a huge pain so a tilter can help give you a little more room to get aggressive. However using a little dielectric grease on the inside of the spark plug boot makes it sooo much easier the next time.
    2010 Camaro SS LS3
  7. #7 Re: Plug wires
    PA
    I tilted the engine the first couple times as well. I didn't have any ratchet straps, and didn't know about rocking the engine with the car on the ground, so I just grabbed ahold of it, pulled on it with one hand, and tied it off with a rope to my workbench with the other. Pretty rigged up, but it worked.
    Now that I have most of the brackets and stuff out of the way in the back, I don't worry about rocking it.
    2001 GSE
  1. MSD Wires
    By PonchoDvr4Lfe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-02-2008, 07:14 PM
  2. spark plug gaps
    By MTXGTP in forum Off Topic Discussion
    Last Post: 03-01-2008, 07:58 AM
  3. 2 unsused wires...what are they for...?
    By Incomudrox in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2008, 01:11 PM
  4. Anyone know where this plug goes/what it is???
    By LowlyfeGTP in forum General Tech Discussion
    Last Post: 01-23-2008, 04:35 AM
