Thread: Unusual noise
Results 1 to 9 of 9
  1. #1 Unusual noise
    SE Level Member PTGsDaytona500GTP's Avatar
    Jul 2010
    Broadview Hts Ohio
    Sometimes when I start up my car it sounds like something is spinning that is not lubed up it's not anything serious because my car runs great and two it doesn't do it all the time anyone have an idea of what I could check out under the hood? Thanks
  2. #2 Re: Unusual noise
    GTX Level Member Juanmiguel's Avatar
    Mexico
    It's kind of hard to point out anything specific with that description. See if you can record a video and post it in youtube.
  3. #3 Re: Unusual noise
    GT Level Member 99GPGTP's Avatar
    Rome GA
    check your starter.
  4. #4 Re: Unusual noise
    Jul 2010
    Broadview Hts Ohio
    well its when my car has started up not when i am cranking her up. it seems to be coming from the froont of the car like a fan or something.
  5. #5 Re: Unusual noise
    GT Level Member mikedinthecity's Avatar
    Apr 2009
    Southfield, Michigan
    some of the idler pulleys on the belts do this alot..it is hard to pinpoint which one it is though. usually u have to take off the belt, maybe wiggle them and see which one has alot of play....
    2000 Daytona 500 GTP. fender well intake K&N, 180 tstat, flipped dog bones, strut2strut brace, sd headers coated n wrapped, 3in dp, 3.25 pulley, pcm tune, led tails, angel eye halos w 100 watt h1s, p&p heads, p&p m90, yella terra alum roller rockers, head studs, 8mm wires, al104s, 2007 l26, 329s hd diff, alum sub frame
  6. #6 Re: Unusual noise
    Rome GA
    use a stethascope and place it on the bolts that hold the pulleys on and various places on the engine and listen to them while the car is running. then u will be abler to figure out where its coming from.
  7. #7 Re: Unusual noise
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Does it sound like its coming from the supercharger? It could possibly be your supercharger coupler or bearings going.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  8. #8 Re: Unusual noise
    GTP Level Member AjL227's Avatar
    IL
    Stethoscope ftw.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  9. #9 Re: Unusual noise
    Jul 2010
    Broadview Hts Ohio
    I don't think it my s/c but i will definitely check and it has not made the noise in a while, i don't know why.
  1. odd noise at 27 mph
    By rossscrappy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2010, 06:01 PM
  2. Odd Noise
    By tdaye in forum General Tech Discussion
    Last Post: 06-19-2009, 07:57 AM
  3. Odd noise, can someone help!!!
    By indybrad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2009, 02:06 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
