Thread: Engine noise from intake...REALLY loud..
Results 1 to 8 of 8
  1. #1 Engine noise from intake...REALLY loud..
    GT Level Member putskijr's Avatar
    Waterloo, Iowa
    I just noticed today on my way to school that theres ALOT of engine noise coming from the intake. also when i got out i smelled a little bit of antifreeze. Im gunna check after school and see what color my oil is. I just changed it saturday so hopefully its not brownish white any other ideas? Ill try and get a sound clip tonight
    180* tstat, homemade FWI, autolite 605's, tuned by FoSho99, clear corners, 6000k hids, painted interior, and sum more
  2. #2 Re: Engine noise from intake...REALLY loud..
    Waterloo, Iowa
    ok so i just looked at it wuick and the enitre left side of the engine bay is covered in antifreeze...i dont have time right now to further investigate but ill be back on around 6 any help would be GREATLY appreciated!
  3. #3 Re: Engine noise from intake...REALLY loud..
    Jul 2008
    nj
    check the plastic elbows that come from the LIM to the pulley tensioner.
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  4. #4 Re: Engine noise from intake...REALLY loud..
    Willoughby, Ohio
    mine did something similar, maybe your UIM gasket went bad, coolant in oil is bad, hurry and get that fixed!
  5. #5 Re: Engine noise from intake...REALLY loud..
    texas
    Left as in transmission side or pulley side, if its the pulley side i would guess the plastic elbow let go, happened to mine just recently
  6. #6 Re: Engine noise from intake...REALLY loud..
    Waterloo, Iowa
    pulley side...ill check for a plastic elbow...any1 have a pic?
  7. #7 Re: Engine noise from intake...REALLY loud..
    Waterloo, Iowa
    not the plastic elbow or heater hoses in back....im thinkin waterpump gasket so ill check that tonight
  8. #8 Re: Engine noise from intake...REALLY loud..
    Waterloo, Iowa
    its the water pump! the thing inside it was grinding the wall twords the motor and has gotten it shaved down a bit...pics 2morrow
  1. Loud Humming noise... What is it?
    By brownb66 in forum General Tech Discussion
    Last Post: 05-14-2010, 10:24 AM
  2. Loud noise at speed
    By ionroller in forum 04+ Specifics
    Last Post: 10-27-2009, 02:26 PM
  3. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  4. Loud Rattling Noise
    By Dangerous313KidInAPrix in forum Brakes/Suspension/Chassis
    Last Post: 03-24-2009, 05:18 PM
  5. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
