Thread: Fuel pressure issues (Delete)
Results 1 to 2 of 2
  1. #1 Fuel pressure issues (Delete)
    Ohio
    Yesterday I drove my car across town and it was working fine when I shut it off an parked it. When I came back about 10 mins later to start it back up and leave it wouldn't stay running. First turn the fuel pump starts and pressurizes the rail like it should i'm seeing about 50 psi but once I actually start it it starts then when the electrical system kicks in at full power it starts idling really rough an then dies and as this is going on the rail pressure is just tapering off. When it gets down to 11 psi it just dies. I replaced both fuel pump relays cause we thought that was it but it didn't work. I need some help! Any ideas?
    00 GTP demodded and forsale
  2. #2 Re: Fuel pressure issues
    Ohio
    nvm fixed! It was the D**N resistor did the bypass an alls good!
  1. oil pressure issues?common or not?
    By strykergxp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2010, 06:18 PM
  2. which fuel pressure regulator to buy?
    By DOUGLASMELTER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2009, 05:09 PM
  3. WOT fuel pressure
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2009, 12:38 AM
  4. Fuel Pressure
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-17-2008, 10:53 PM
  5. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
