Thread: MAF sensor on GP 2004 GTP
Results 1 to 4 of 4
  1. #1 MAF sensor on GP 2004 GTP
    SE Level Member armed's Avatar
    Canada
    HI guys. I am going crazy. For the past 3 weeks, my CEL has been on with codes P0069 (Manifold Absolute Pressure - Barometric Pressure Correlation) and P2229 (Barometric pressure circuit high input). I am suspecting MAF sensor, MAP sensor, or both (hopefully not the actual computer).
    I wanted to start with the MAF sensor because the RPM plays around when the car is in neutral and when trying to use the remote start feature, it turns on and hesitates then turns off.
    I called the dealer and they said the part needs two weeks to arrive. So I called a few other auto parts store and found the MAF sensor. When I got there, they gave me a part that is not the same as mine. I told them this is different. They kept trying to find the right part but this is all the computer gave them as MAF sensor for Pontiac Grand Prix 2004. Same thing at another auto parts store.
    Please take a look at the pictures I attached and tell me if I am doing something wrong. Is this the MAF sensor or am I going crazy?!!
    Any help is greatly appreciated. Thanks
    Glowfoto :: Photo Sharing
    and
  2. #2 Re: MAF sensor on GP 2004 GTP
    Donating Users blowfishRus6's Avatar
    g.a.
    yea, thats the maf. unplug it and see if it runs any different.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Update
    Canada
    So I replaced my MAF sensor. I am only getting one code now which is P2229. I am guessing this is the map sensor? Anyone have any knowledge about this? When I took the cover off, I saw two sensors on a bracket to the rear of the the engine. Does it have two MAP sensors?
  4. #4 Re: Update
    Feb 2014
    Minnesota
    Yes they are identical sensors one is MAP the other is Barometric Pressure.
    Did you ever figure this out?
  1. 2004 with '84 350
    By sportsman1212 in forum General Tech Discussion
    Last Post: 08-22-2009, 03:08 PM
  2. 2004 gtp abs
    By justmebobg in forum Introductions/Noob Questions
    Last Post: 07-05-2009, 12:52 PM
  3. 2004 gt
    By green mountain goat in forum Introductions/Noob Questions
    Last Post: 06-16-2009, 05:43 PM
  4. 2004 lincoln Lsv8 or 2004 GP GTP?
    By Enjoijoe in forum General Tech Discussion
    Last Post: 03-10-2009, 03:58 PM
