Thread: car started then dies
Results 1 to 20 of 21
  1. #1 car started then dies
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok i need some help my car just died on me when i was driving and now it idles for about 10sec and then dies again. no check engine light or anything. i have no clue where to even start to look so any help would be really great.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: car started then dies
    Willoughby, Ohio
    i would say MAF sensor or CPS...try unplugging the mass air flow sensor and see if the car still dies.
  3. #3 Re: car started then dies
    Grayslake
    i tried unplugging the maf whats the cps?
  4. #4 Re: car started then dies
    Willoughby, Ohio
    crank position sensor, which i believe is slowly going out on my car as well. it will stall at traffic lights with no warning or dummy lights randomly. but its done it 3 times and hasnt done it since (knock on wood)
  5. #5 Re: car started then dies
    Grayslake
    where is it at like what side
  6. #6 Re: car started then dies
    Jul 2008
    sumter,south carolina
    check fuel pressure, whens the last time fuel filter has been changed?
    02 GTP with mods 05 GP for DD
  7. #7 Re: car started then dies
    Jul 2008
    Quote Originally Posted by grand2000prixgtp View Post
    its a ***** to get to, theres a writeup in the how to section on it. id check easier fixes first...
  8. #8 Re: car started then dies
    Grayslake
    it was changed about a year or so ago and it has pressure i think cause i can rev it up and stuff
  9. #9 Re: car started then dies
    Jul 2008
    rpms drop to zero while driving at all?
  10. #10 Re: car started then dies
    Willoughby, Ohio
    its behind the harmonic balancer, not the easiest to get to... heres the cps writeup
    http://www.grandprixforums.net/cps.php
  11. #11 Re: car started then dies
    Grayslake
    i cant even drive it i can start it and rev it but if i try and let it idle it dies and when i am reving it it dies sometimes
  12. #12 Re: car started then dies
    Jul 2008
    go check the T boot vac connection under snout of supercharger....its on the intake manifold.
  13. #13 Re: car started then dies
    Canada
    That just happened to me and it was the Fuel Pump....Does it sputter or cut out when you rev it above 2500??
  14. #14 Re: car started then dies
    Grayslake
    ok ill have to look at the vac lines. no it does not sputter above that i had to replace the fuel pump like a year ago
  15. #15 Re: car started then dies
    Jul 2008
    how many times have u tried cranking it? does it actually stay running for 10 seconds at a time each time u start it? swap fuel pump relay around too.... i forget which one it is under fuse box but they are labeled on fuse box cover, theres one or two relays that are the same as the fuel pump relay .
  16. #16 Re: car started then dies
    Willoughby, Ohio
    or bypass the fuel pump resistor and see if that helps
  17. #17 Re: car started then dies
    Grayslake
    well i put different relays in it and it still does the same thing. and it only runs for 5sec if u just try and let it idle but if i rev it up and can keep it running for longer
  18. #18 Re: car started then dies
    Jul 2008
    id replace fuel filter even though it was done last year, did u check vac lines?
  19. #19 Re: car started then dies
    tacoma
    Hey, I just went through the exact same thing. Its an easy fix and free. Pull out the pass side headlight assy, behind it on the fenderwell is a plug. Its your fuel pump resistor. Unplug it and put a paper clip or wire into the female end, and loop it into the other side of that same plug. It should start and stay running. Its a temp fix but you'll be able to drive. Get a new resistor
  20. #20 Re: car started then dies
    Grayslake
    where do i get a new resistor at
  1. help get me started?
    By DDPeppa in forum Introductions/Noob Questions
    Last Post: 03-11-2009, 05:38 PM
  2. Finally got started
    By swtwcgtp in forum Audio, Security & Visual Electronics
    Last Post: 08-10-2008, 10:32 PM
  3. Who started this fourn?
    By Gearhead43 in forum Off Topic Discussion
    Last Post: 01-04-2008, 09:53 AM
