Thread: tapping in engine
Results 1 to 17 of 17
  1. #1 Re: tapping in engine
    SE Level Member almighty's Avatar
    northern illinois
    well im going to throw it on the lift tomorrow and check the flex plate, that will be 2 in 6 months if it is. i figured screw the oil pressure if its a rod then its gone, i do have plans to put a gauge in asap, but i dont trust plastic line and all seems to be good and strong. i will update this with info about a blown motor or a small crack in the flex plate.
  2. #2 Re: tapping in engine
    Spring, TX
    I took mine to the dealership and they said exhaust leak, but I have yet to confirm because of the money issue. Good Luck, I have the same noise, "basically" it goes away after the engine heats up.
  3. #3 Re: tapping in engine
    Largo, Florida, United States
    Quote Originally Posted by danielbrazz View Post
    yeah i have a squealing belt issue for the first 5 mins my car is on.
    then it goes away
  1. HELP-metallic tapping sound, what could it be?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-03-2009, 08:43 PM
  2. loud tapping noise
    By blown98gtp in forum General Tech Discussion
    Last Post: 03-04-2009, 03:40 PM
  3. My engine tapping noise with Video
    By 04CompG in forum General Tech Discussion
    Last Post: 12-12-2008, 02:57 PM
  4. Tapping power from Amp.
    By m0ng00se in forum Audio, Security & Visual Electronics
    Last Post: 10-04-2008, 07:57 AM
  5. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
