Thread: p0420 codes... common??
Results 1 to 3 of 3
  1. #1 p0420 codes... common??
    AK
    is the cat efficiency code a real common gm problem? any fixes? would a high flow cat/02 emmulator fix the problem and still pass I/M?
    car is a grand prix 3.8L S/C
  2. #2 Re: p0420 codes... common??
    MA
    I dont know if the problem is that common but I have it showing
    SMGPFC Member #9
  3. #3 Re: p0420 codes... common??
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    I have had it come and go since I got my 03 GT @ 75,000. I have tried 3 or 4 universal cat's after the factory one started to plug. I ignore mine, each time the cat was covered under warranty so I am not out much. I do have a $45 scanner I will check codes every once in a while to be sure nothing else has shown up.
  1. P0420 code
    By BChimo in forum General Tech Discussion
    Last Post: 10-18-2012, 12:18 PM
  2. P0420 code
    By Madness in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2010, 03:25 PM
  3. P0172 and P0420 Codes
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-16-2010, 10:21 PM
  4. p0420 02 gtp
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2009, 10:52 AM
  5. p0420 code on
    By fst in forum General Tech Discussion
    Last Post: 01-05-2008, 04:19 PM
