Thread: Rapping/Rattle at Idle, goes away when revving
Results 1 to 10 of 10
  1. #1 Rapping/Rattle at Idle, goes away when revving
    AZ
    Hi folks. I have gotten some help here before, and am hoping to get it again. I have a 2000 GTP, 3.5 pulley, CAI, stock other than that, 139k, needs an oil change but not low on oil. Last weekend I changed my battery, and yesterday it rained really hard, these are ust a couple recent variables to the car. Yesterday driving home, it developed a bad rapping sound/rattle kind of knocking sound at idle, as soon as you get over 900 rpms it stops, and doesnt come back til falling back to that range. I have no check engine light on, no smoke, and the car runs exactly as it should. I even got it on the boost to make sure and it was fine. I really don't know if this is internal or not, but I feel like I can hear the internals of the engine running seperately from this sound. The sound certainly seems loudest on the pulley side of the car. Also when it starts, it sounds like something might be catching or something like that. My gas milage has always been kind of crappy so nothing major changing there. Any advice? Thank you in advance!
  2. #2 Re: Rapping/Rattle at Idle, goes away when revving
    Charles City, IA
    Start you car with out the belts on and see if the noise is still there.
    SMGPFC Two Nipple General
  3. #3 Re: Rapping/Rattle at Idle, goes away when revving
    AZ
    Alright, going to see if I can find a shade tree mechanic to do it, I don't have the tools here...Thank you for the tip
  4. #4 Re: Rapping/Rattle at Idle, goes away when revving
    AZ
    So I have not had a chance to take the belt off yet, but using the skill I do have I have figured out that I am almost 100% sure it is some kind of bearing /pulley issue. As soon as I clicked on the AC (Something I havent done since I heard the noise the first time) the noise quieted. Something is making a rapping sound unless it has tention on it basically. Any tips from here?
  5. #5 Re: Rapping/Rattle at Idle, goes away when revving
    you should prolly put your STOCK pulley back on too. Unless you want that motor to go bye bye. you have ZERO flows mods and ur running a smaller puley.
  6. #6 Re: Rapping/Rattle at Idle, goes away when revving
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    put stock pulley back on its prolly your motor knocking... or a bad supercharger coupler
  7. #7 Re: Rapping/Rattle at Idle, goes away when revving
    AZ
    The car has had that pulley on it since I bought it, I forgot to mention it does have a performance edu as well. It has never been an issue. I do not think its knocking, because the sound is not at all in time with the sound of the internal engine movement.
  8. #8 Re: Rapping/Rattle at Idle, goes away when revving
    Jul 2008
    sumter,south carolina
    could be a number of things... supercharger coupler, a bad pulley, even a cracked flex plate. mine is cracked at the moment and the noise will go away when i turn A/C on. lets hope its not my problem that im having.
    02 GTP with mods 05 GP for DD
  9. #9 Re: Rapping/Rattle at Idle, goes away when revving
    SE Level Member Kstuck's Avatar
    Jul 2010
    Grand Blanc, MI
    I am not very car savvy, but a family member had this issue with a park ave and it was the AC Clutch, not sure if its relevant to this or not just trying to help.
  10. #10 Re: Rapping/Rattle at Idle, goes away when revving
    Denver
    When the engine is running, take a long screwdriver and place it against the s/c snout. Take the other end (handle) and place it against your palm while your ear is resting against the outside of your hand. You will be surprised what you can hear using the screwdriver as a conduit.
    My guess: bad supercharger pulley.
    When mine was worn out (120k miles), it sounded like rocks were tumbling inside my engine. I could only hear at idle. It was so bad that I was sure the needle bearings were trashed. When I cracked it open (took the lobes out and everything), the only thing that was bad was the pulley.
    The car has been whisper quiet ever since replacement.
  1. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  2. Engine Revving after filter change
    By mikeh in forum General Tech Discussion
    Last Post: 01-18-2010, 12:29 AM
  3. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  4. rattle on accelleration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:31 PM
  5. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
