Thread: Noisy supercharger at air intake
Results 1 to 20 of 24
  1. #1 Noisy supercharger at air intake
    SE Level Member Purple Plazma's Avatar
    Nov 2009
    Trevose,PA. (near Philly)
    I noticed the area of the supercharger where the mas airflow sensor(?) is located , where the air enters the unit on the left side,makes one hell of a loud racket when the car is running but still cold.I doubt it's been serviced at all it's entire 79K mile life. If I'm gonna rebuild this car, make it look fantastic, and be safe to drive, I might as well be assured the sc is in top shape. I've seen adds on ebay for an outfit in South Jersey that has reconditioned units .I assume they have a core charge. My question is, what can I expect to pay for a "re-conditioned" unit and who does it with the best workmanship? I already got seriously "hosed" with the purchase of this rust bucket, can't afford to get a re-conditioned supercharger that is poorly done. I'm not looking for mega h.p. here, just needs to be back to original GM specs and output. Sorry if this is an OLD question that's been answered dozens of times already.
    Steve
  2. #2 Re: Noisy supercharger at air intake
    Jan 2009
    Tallahassee, FL
    What kind of noise is it exactly? With an intake the motor gets a hell of a lot louder, especially cold.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  3. #3 Re: Noisy supercharger at air intake
    Nov 2009
    After putting my ear closest to the inlet (as described above), it was a loud mechanical "clatter". I'll probably exchange for a reconditioned one anyway.
  4. #4 Re: Noisy supercharger at air intake
    Does it sound like a metal shovel being dragged along a concrete driveway? If it only does it when it is cold then it is the IAC in the TB...its loud...and normal. The SLP Air Box on my mom's '03 L36 LeSabre is louder than crap at idle (and yeah...I put a SLP box on it...I know...awesome)...when it warms up...no more sound.
  5. #5 Re: Noisy supercharger at air intake
    Nov 2009
    It only does it when cold. "IAC in the TB" I still need to learn all the acronyms. Does sound like the shovel being dragged across a stone driveway. How do I check to see how "healthy" my supercharger is before I buy a reconditioned one?
  6. #6 Re: Noisy supercharger at air intake
    Jersey
    i wish my car would run like that all the time, sounds raunchy
    16' wrx sti- stock
  7. #7 Re: Noisy supercharger at air intake
    Idle Air Control.
    Does it make this sucking sound? YouTube - 2002 Pontiac Grand Prix GTP 3.4 pulley first start up
  8. #8 Re: Noisy supercharger at air intake
    Nov 2009
    Yeah, that racket sounds familiar. Actually, it's not the engine that sucks, it's the condition of the rockers, etc. that SUCKS! Is it common for the IAC to go bad on these engines? Any advice is appreciated.
  9. #9 Re: Noisy supercharger at air intake
    Maybe...but it would cause the idle to be sporadic.
  10. #10 Re: Noisy supercharger at air intake
    Nov 2009
    Mine idels perfectly. Guess I'm just used to the much quieter LT1 in my Roadmaster.
  11. #11 Re: Noisy supercharger at air intake
    L67 isn't a very quiet motor. Maybe get a video of it just to be sure...could be a bad coupler in the blower too
  12. #12 Re: Noisy supercharger at air intake
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    dude, i made a 4" hoomeade intake for mine and it is horribly loud, when cold only , then it warms up and is so quiet.. don't worry (sound) about it.
  13. #13 Re: Noisy supercharger at air intake
    Nov 2009
    Sheridan,Indiana
    I get the same noise. I freaked out like you were and rebuilt my supercharger, all bearings and coupler only to find the noise is still there. I even started the car after removing the supercharger belt and its still there. Goes away after it warms up. usually in 1 or 2 minutes.
  14. #14 Re: Noisy supercharger at air intake
    Nov 2009
    Quote Originally Posted by Doerr View Post
    About how much to rebuild the SC? Who performed the work? And, would you recomend them? I'm thinking with almost 80K miles on my unit it's probably a good idea anyway.
  15. #15 Re: Noisy supercharger at air intake
    Nov 2009
    Sheridan,Indiana
    Quote Originally Posted by Purple Plazma View Post
    I rebuilt the SC myself.
  16. #16 Re: Noisy supercharger at air intake
    Have Reptile do it...been doing blower porting for a long time...send him a PM on here...he can port it while he has it too.
  17. #17 Re: Noisy supercharger at air intake
    new york
    It's normal. Ive heard it in a 1500 mile gtp with a filter strapped to the tb. And ive heard it on high mile 3800's as well. It goes away after a little warm up.
  18. #18 Re: Noisy supercharger at air intake
    Wooster, Ohio
    maybe a newb question, but anyone know how often its recommended to change the S/C oil out?
  19. #19 Re: Noisy supercharger at air intake
    Wausau, WI
    so, do you recommend yourself?
  20. #20 Re: Noisy supercharger at air intake
    Nov 2009
    Sheridan,Indiana
    Quote Originally Posted by Liquifire View Post
    Its really not a big deal to do. Buy all the parts you will need and rent a small inside bearing puller and your good to go. I thought it was harder to remove the SC from the car than to rebuild it. If you have any mechanical ability at all its pretty easy. If you live in indiana I will help you.
  1. Noisy blower motor (HVAC fan )
    By ChupakabraKing in forum General Tech Discussion
    Last Post: 06-12-2009, 11:42 AM
  2. Coolant Loss, intake Gasket or Intake Itself???
    By WoR in forum General Tech Discussion
    Last Post: 04-29-2009, 04:02 PM
  3. noisy flex
    Last Post: 04-11-2009, 01:22 AM
  4. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
