Thread: Easy Performance Flow Charger
Results 1 to 3 of 3
  1. #1 Easy Performance Flow Charger
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    I just purchased the Easy Performance Flow Charger and when I look at the directions they are basic as ever. Im not sure where to splice into the positive fuel pump wire or where to even mount the box. Can anyone help me out? Thanks a bunch.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #2 Re: Easy Performance Flow Charger
    Feb 2008
    Houston
    All these brains here and no help.............
  3. #3 Re: Easy Performance Flow Charger
    Saraland Alabama
    as far as splicing position doesn't matter, just do it in a place that is easy to protect from moisture I would say you could accomplish that by using the access panel in the trunk, and mount the box in the trunk (I don't have one, but that is what makes sense to me)
  1. Trany shifts Hard down but easy up
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2008, 12:03 PM
  2. Need help spending some money (This should be easy)
    By TDCRacing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-08-2008, 01:02 PM
  3. Easy Dent Removal
    By SyntheticShield in forum Visual/Body Modifications
    Last Post: 04-04-2008, 05:17 PM
  4. Intercooler Flow???
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2008, 08:45 PM
  5. Scooper-charger?
    By flynn in forum Off Topic Discussion
    Last Post: 01-11-2008, 08:06 AM
