i have a 2000 gtp that dies randomly, it did it a few times and when i put it in nuetral to push it to the side of the road it will always restart but the traction control off light is on and cant be turned back on. i realy didn't get a chance to troubleshoot it untill the other day, the fuel pump is working and has good pressure, i checked as many connections as i could without lifting the car and everything seemed fine, checked for spark and there was none. swapped in new relays and still no fire. the thing that has me baffled is i out of the blue tried to put it in nutral and move it a bit and try it, it fired right up! tcs off light on but it ran. im confused as to what could be causing this. any advice?
