Thread: Underlying problems?
Results 1 to 16 of 16
  1. #1 Underlying problems?
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    I decided to put my stock PCM back in to try to fix the problem I have been having which can be found here: http://www.grandprixforums.net/rpms-...ing-58482.html
    Well, now my car runs like sh*t. I stepped on it and it was extremely hesitant and jumpy for the first little bit. After about 5 mins it wasnt as jumpy, but it still felt like it was lacking a lot of power. When I stepped on it again it shifted to 2nd gear and I heard a loud squeak. I tried it twice and both times the squeak was loud between the 1-2 shift. I decided to drive it home and park it until I can figure out whats wrong.
    It wasnt hesitant and I never heard that squeak with the overkill PCM in.
    Any ideas?
  2. #2 Re: Underlying problems?
    Antioch, IL
    any codes pop up?
    I put my 2nd overkill in and it stopped the rpm bounce, but now I have 8.5 degree of timing at wot. You win some you lose some HAHAHHA. Dammit
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: Underlying problems?
    May 2011
    No codes yet, I might take it for a quick drive again to see if anything pops up.
    And lol that sucks, no wonder your acceleration wasnt as good haha.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Wow...... alot of problems with overkill pcms it seems like......
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  5. #5 Re: Underlying problems?
    What have I been telling people all these years.
    DHP PCM or bust.
    Orange County, NY
    It should be common knowledge that the dhp has always been the best pcm box tune.
  7. #7 Re: Underlying problems?
    Quincy, Mass
    what was the maf code? a bad maf can cause your shift points to be messed up.
    No more GP 04 Impala SS Indy:
  8. #8 Re: Underlying problems?
    May 2011
    Im not sure, I cleaned it and it went away. I had p0403 and p0405 pop up on me when I went outside. I forgot to plug the EGR in, so I plugged it cleared the codes and took it for a ride and no improvement. The acceleration is extremely "jerky".
  9. #9 Re: Underlying problems?
    Antioch, IL
    Throw overkill back on and see if anything changes? Maybe you tweaked something and didnt notice it.
    I must have swapped pcms 50 times in 1 week lol.
    May 2011
    Ya I'm going to throw the overkill PCM back in and see what happens.
  11. #11 Re: Underlying problems?
    Or, unplug the MAF and take it around the block and see if the trans shifts any better...
    Too add, what kind of mileage is on the car (in that 'merican numerals...not that kilo mess, lol.) and has the transmission ever been serviced, pan drop, filter change, shift kit, etc.
    May 2011
    Ill try unplugging the MAF and see if its any better. It has around 115,000 MILES and as far as I know the tranny hasn't been serviced.
  13. #13 Re: Underlying problems?
    Could be a clogged trans filter...mine is starting to act up now...check the fluid when you can...should be red-er than your car color...and shouldn't smell burnt...if it does, that COULD very well be the "underlying" issue.
  14. #14 Re: Underlying problems?
    May 2011
    Trans fluid looks bright red. Unplugged the MAF and the car ran like a champ, no sloppy shifts and smooth acceleration.
    Orange County, NY
    Looks like u found ur problem
    Quincy, Mass
    Yup sounds like a bad maf.
  1. 2 problems HELP!!!
    By Frank4202 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 07:04 PM
  2. 01 gtx problems
    By black01gtx in forum General Tech Discussion
    Last Post: 05-10-2011, 11:09 PM
  3. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  4. MAF problems (i think) HELP!
    By Nig Gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2010, 06:31 PM
  5. problems problems problems!
    By NomeCrusher in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-14-2009, 03:26 PM
