Thread: 1999 gtp keeps kickin me in the b***s
Results 1 to 7 of 7
hubert hefner 1999 gtp keeps kickin me in... 03-23-2010, 09:23 PM
rynoman03 Re: 1999 gtp keeps kickin me... 03-23-2010, 09:36 PM
hubert hefner Re: 1999 gtp keeps kickin me... 03-23-2010, 09:43 PM
rynoman03 Re: 1999 gtp keeps kickin me... 03-24-2010, 03:17 AM
hubert hefner Re: 1999 gtp keeps kickin me... 03-24-2010, 10:13 AM
rynoman03 Re: 1999 gtp keeps kickin me... 03-24-2010, 07:41 PM
hubert hefner Re: 1999 gtp keeps kickin me... 03-25-2010, 07:54 AM
  1. #1 1999 gtp keeps kickin me in the b***s
    rochester,in
    Ok so i'm workin on this 99 gtp for a guy. the car quit running and it seems like the more i do the more i find wrong i am about to get a stick of c4. So here is what has happened and the things that i have done and so on.
    i picked the car up (non-running of course) no battery had to un hook the shift linkage to get it on the trailer blah blah blah. He says that it wont stay running it will run for about a minute and then it will die and wont run after that. So i get it home put a battery in it start it up pull it off the trailer and pull it in the garage and let it run until it dies(so i can see what its doing). it ran for about a min and got rough and died. tried starting it back up and it would fire and then die. i was getting a random miss fire code on the scanner. I checked the fuel pressure and it was low like 20psi, so i changed the fuel filter that was clogged so bad you couldn't blow through it. started the car again after that and checked the pressure it ran better for like 10 min then died and started doing the same thing again, the fuel pressure was better though it was like 50psi now.
    I changed the plugs and wires(the plugs were fouled and the wires were shot). that help for a little bit anyway. then it would purr like a kitten and then it started acting up again. more more codes coming up at all. seems like one thing right after the other. today i checked the tps be cause it would start jumping around at idle before it died. the tps wasn't reading right so i changed it and it didn't fix the problem. it kept going from lean to rich and so forth and misfiring like crazy. so i took the throttle body off and it was leaking coolant in to the s/c housing and it was black and gooey in there so i cleaned it all up and am going to put it back together in the morning. i am thinking that the MAF may be bad but its not throwing any codes and the scanner says that its working. but im not convinced that its good. This thing is really testing my patience. so what do you guys think? any ideas. hope i bout got the nail hit on the head.
  2. #2 Re: 1999 gtp keeps kickin me in the b***s
    Topeka, KS
    Unplug the MAF and see if it runs better without it. If it does your MAF is bad. Also look for vacuum leaks. You've done everything i would have to start out. Also post the codes you are receiving so we may help diagnose your problem a little better.
  3. #3 Re: 1999 gtp keeps kickin me in the b***s
    rochester,in
    Ok thanks. i got a p0300 and a p0650 which is a random misfire and a MIL circuit. The SES is burnt out though. It has a slight misfire on the #1 cyl but the guy broke off a couple of bolts that hold the coils on and thought he would JB weld them on. LOL cant believe that. can you drive it without the MAF plugged in for a while or no? i was gonna take the charger belt off tommorow and see what that does to but i'll do the MAF first. i need to find a vaccum t that goes on the front of the s/c also it was rotted.
  4. #4 Re: 1999 gtp keeps kickin me in the b***s
    Topeka, KS
    Go to your nearest autoparts store and fix that vac. leak. Yes you can drive you car without the MAF it just idles a bit funny when starting it. Sounds like your Coils could be hosed if someones been jb welding stuff back together.
  5. #5 Re: 1999 gtp keeps kickin me in the b***s
    rochester,in
    yea i wen to the parts store and couldnt find a rubber vaccum t, i'm gonna look at napa too though. it was just misfiring every now and then. im thinking that the maf is the main problem. but this car has had the crap beat out of it though. I appreciate the help though. hope to have it figured out today though if im lucky.
  6. #6 Re: 1999 gtp keeps kickin me in the b***s
    Topeka, KS
    Well i patched mine up with auto zone vac line parts then i went and re-ordered that whole Assy. at my local dealership. You won't fine the T you have to get a plastic vacuum T and put rubbers on all 3 sides and make it work...
  7. #7 Re: 1999 gtp keeps kickin me in the b***s
    rochester,in
    yea i got it all fixed. fixed the vacuum leak, he bought another engine before he broght it to me to look at b/c he thought it was blown and i took the vacuum t off of the other engine, but the didn't give him the TB though. i put it all back together and unhooked the MAF and it came right out of it, runs great. Thanks for the help.
  1. 1999 gtp debadging
    By thecon23 in forum Visual/Body Modifications
    Last Post: 06-14-2009, 03:00 PM
  2. 1999 se to gt?
    By Dboy23 in forum Visual/Body Modifications
    Last Post: 09-22-2008, 10:27 PM
