Thread: boost gauge question
Results 1 to 7 of 7
  1. #1 boost gauge question
    Jan 2009
    connecticut
    I know this is a noob question, but i had someone install a boost gauge and aeroforce today and at idle the boost gauge stays at around 4 psi and never goes into the vac part. he told me its normal because the supercharrger is always making boost, i say he's full of ****. someone give me the right answer please!!
    K & N cai / 3" downpipe / hi-flow cat / u-bend delete / 180 T-stat / ceramic coated plog & crossover / Overkill pcm / 3.5" pulley / zzp stage 1 TB / auto lite 104's / msd wires / poly mounts / slp front and rear sway bars / bmr trailing arms /
  2. #2 Re: boost gauge question
    GTX Level Member real diehl's Avatar
    Salina, KS
    It should be at vacuum, especially at idle.
    signature removed for inappropriate content.
    -bio
  3. #3 Re: boost gauge question
  4. #4 Re: boost gauge question
    Jan 2009
    connecticut
    thats what im saying, i knew he was wrong. could it be where he tapped it into thats causing bs reading. he connected it to a hose on top of the supercharger just past the throttlebody. i found it to be a weird spot because i thought most people connected it near the s/c snout.
  5. #5 Re: boost gauge question
    yeah, thats the wrong spot. youre supposed to connect it to the vacuum line that runs around the base of the blower. it hits the BBV, FPR, LIM, and MAP sensor. buy a rubber T and tee off the MAP sensor behind the blower and run it into the car from there. it keeps it cleaner coming from the back already.
  6. #6 Re: boost gauge question
    Jan 2009
    connecticut
    Thanks bio, your the man! i'll get on it tomorrow, knew that guy was full of ****, i wish i had more time to do my own work.
  7. #7 Re: boost gauge question
    Charles City, IA
    Diesels dont even make boost at idle.
    SMGPFC Two Nipple General
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. Factory boost gauge question (98GTP)
    By JoelW98GTP in forum General Tech Discussion
    Last Post: 11-08-2009, 08:06 PM
  3. question about boost gauge on a 98 gtp
    By millfire517 in forum General Tech Discussion
    Last Post: 02-09-2009, 08:31 PM
