Thread: Needle Bearings falling out of Driver Trans Axle
Results 1 to 5 of 5
  1. #1 Needle Bearings falling out of Driver Trans Axle
    SE Level Member justlookin's Avatar
    Apr 2009
    Whitby Ontario
    Replaced driver axle to day and needle bearings fell out of the Transmission. This is not good i have had the car for 2 weeks.Is there a repair or is this a rebuild problem.When i bought this Gtp the owner told me there was a slight clicking left side.
  2. #2 Re: Needle Bearings falling out of Driver Trans Axle
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Those needle bearings are in a race that's installed in the channel plate. If you pull the seal, you MAY be able to pull the bearing, but it won't be easy. Best would be to take the channel plate out, but that involves dropping the driver side of the subframe a few inches, removing the side cover, wiring harness, pump, valve body, and finally channel plate.
    Why couldn't it have been the passenger side, that one would be much easier.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Needle Bearings falling out of Driver Trans Axle
    Wichita, KS
    ^What he said.
    I would remove the channel plate and do it out of the car. I had to replace my bearing there too because the race had a "chip" taken out of it, and it would allow the bearings to fall out. I didn't want to take the chance of it turning into a grenade, so I replaced it with a new one.
    I used a bearing/seal driver tool kit from my brother, and my arbor press to insure I did it smooth, and correctly.
    ~F~
  4. #4 Re: Needle Bearings falling out of Driver Trans Axle
    Apr 2009
    Whitby Ontario
    Hey thanks well after much research i was going to do just that and remove channel plate. I was quoted 900.00 to repair.I say not going to happen.I can do this work but without insight we are blind. ( agreed) Thanks for your information.
  5. #5 Re: Needle Bearings falling out of Driver Trans Axle
    Apr 2009
    Whitby Ontario
    Well job done and i feel it could have not gone any better.When taking apart for inspection other problems were evident.Thrust washer for VSS and 4th gear hub.Clutch plates had wear and the apply plate was installed backwards.Given all this i replaced all affected parts.This transmission is better then i thought it could be. So again i say thank you all for the information.Now my 03 gt is acting up with trans issues. Oh what fun to have 2 GPs.
  1. Bad trans or axle?
    By Black18Ice in forum General Tech Discussion
    Last Post: 08-11-2009, 08:40 PM
  2. Guage needle
    By DDPeppa in forum General Tech Discussion
    Last Post: 06-01-2009, 03:25 PM
  3. Driver's side axle / halfshaft issue...
    By GrandPrixGT300 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2009, 04:00 PM
  4. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  5. Needle In Haystack?!?!
    By Toasty in forum General Tech Discussion
    Last Post: 02-26-2008, 02:17 AM
