Thread: zzp short stack ic
Results 1 to 13 of 13
  1. #1 zzp short stack ic
    chicago
    anyone bought one and wish they got the full size ic instead? i was looking at the full size one, but still debating if i want to dump over $1k on getting it. the short stack ic is half of that price which i can afford it easily. beside the amount of * of heat it can remove and smaller pulley i can drop for the full size ic what are other advantages? i kinda wish i bought wbody store ic few years ago when they sell it cause the price was little cheaper than zzp.
  2. #2 Re: zzp short stack ic
    Jan 1970
    Maquoketa, Iowa
    You could always try to see how it works with a volkswagon FMHE on ebay, it's the same as ZZP's stage 4, people have made it work with the A/C still functioning. Depends on what you want to do with your car, drop down to a 2.8", yes stg 2, but A SSIC will work if you want to keep it at a 3.2" pulley with a few other mods, maybe race gas and a 3.0" at the track. The difference in temperature drops is noticable, but you can try and push the limits of the SSIC.
  3. #3 Re: zzp short stack ic
    the short stack will help you out if you ever get an aftermarket hood. some of them won't clear with the full size. if youre only looking to run low 13s, max of high 12s, an ssic would be better because itd be overkill and a waste of money to go fullsize.
    its all about your preferences.
  4. #4 Re: zzp short stack ic
    chicago
    i don't really trust ebay stuff i'll stay clear from that. i talked to mike k he said he said check back next month. i'm running 3.1 mps right now. we'll see when wbody store have their ic out and i'll either get from mike k or zzp. i probably end up getting full size.
  5. #5 Re: zzp short stack ic
    Jan 1970
    Maquoketa, Iowa
    If your already running a 3.1", yah you might as well get the full size. Do you have a built tranny? I just bought a used Stg 2 setup today with a stg 3 FMHE and other goodies.
  6. #6 Re: zzp short stack ic
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by silverbullet View Post
    It seems nearly everyone that went SSIC either went full sized later or wished they had. I had a Stge 3 for a while and it really did keep the blower much cooler. I was able to lay my hand on the blower after driving 4 hours home from Indiana. I thought that was quite impressive.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  7. #7 Re: zzp short stack ic
    SE Level Member kamper98's Avatar
    Mandan, North Dakota
    Yes. I ran a SSIC for just under 2 years, and now currently just installed a fullsize. All depends on how far you want to go and what your goals are with the car. I always said a ssic and a 3.2 was the farthest i would go. Now i have a fullsize with a 3.0 on.
    S2 I/C, ZZP FMHE, 3.0", TOGS, FWI, 3" DP, 42.5 lb. injectors, 1.9's, 104's, Fuel pump rewire, Flowmasters, ZZP machined intake, N*, LQ4, ZZP Fuel Logs w/ PRJ regulator, AN Fuel lines, Ported I/O Gen 3, F-body 12in Brakes, 8 rib, HPTuner
    Car SOLD
  8. #8 Re: zzp short stack ic
    GT Level Member Going Too Phast's Avatar
    Quote Originally Posted by kamper98 View Post
    Do you have that SSIC core still?
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  9. #9 Re: zzp short stack ic
    Saraland Alabama
    my opinion is if your going to do something like intercool, why go halfway?
  10. #10 Re: zzp short stack ic
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    well if you are going to only go so far why spend the $$$$$$$$$$
  11. #11 Re: zzp short stack ic
    TDCRacing
    Guest
    Quote Originally Posted by jacobmh27 View Post
    well...speed is addicting...thats all i got to say
  12. #12 Re: zzp short stack ic
    Naugatuck CT
    true true
    chicago
    well, when i first bought my 04 monte carlo ss supercharged 300whp was my goal and that's it. after the xp was installed my whole plan changed. i went from xp to ported heads, rebuilt tranny and etc, etc. most of the parts on my monte either rebuilt or after market stuff. i think i'm little over 300whp right now. i'll find out saturday when i dyno it. basicly i'm not trying to make this a track car i'm trying to make this a fast fun street car, faster than stock that is. there's a lot of monte carlo here in chicago, but most guys have big wheels or not mod. i want my monte to be little different than the rest. i want my to be all show and go. i think i reach the point of modding now, after i get the ic that is. i still do want to hit the track once. i'm going to have to get the full size cause i know myself that if i get the ssic i will regret it later.
  1. Short Shifter [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 05-01-2012, 10:23 AM
  2. Short Stack Intercooler [*]
    Last Post: 04-30-2012, 04:20 PM
