Thread: ZZP oversized radiator, link to the cheaper ones on Ebay?
Results 1 to 17 of 17
  1. #1 ZZP oversized radiator, link to the cheaper ones on Ebay?
    Donating Users Tengis's Avatar
    Houston
    Im basically asking who makes them and where I can get one NOT from ZZP since I know they can be had cheaper.
    Link me!
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Saraland Alabama
    they are probably griffin or be cool (just a guess but those are the 2 biggest manufacturers out there)
  3. #3 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
  4. #4 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    I have the ZZP one and damn does it make a difference, the needle goes no where... *edit* after it gets to temp of course lol
  5. #5 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Moore, Oklahoma
    Ok, so which PN is it? I see several different numbers in the post, what is it? I need to do this mod next. I figured if I couldn't find the proper rad, i'd just buy one from WBS...
    The one PRJ posted... if you buy that one you'll get 1" CORE, a couple people had that happen on CGP...
    Shawn W. Larsen
  6. #6 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Las Cruces, NM
    432694 from rockauto.com
  7. #7 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Moore, Oklahoma
    Hey Vinnie,
    Have you gotten this radiator recently? The price is great, and I want one, I just don't want to end up like many and get a 1" rad. Will this bolt up to a 1999? Or do I need the adapters?
    Thanks
    Shawn W. Larsen
  8. #8 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Las Cruces, NM
    I only found the info, I haven't ordered it yet.
    http://www.grandprixforums.net/f49/b...tion-2156.html
  9. #9 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    SE Level Member black.gtp's Avatar
    Apr 2008
    Indiana
    Quote Originally Posted by Iron Indian View Post
    Hey Vinnie,
    Thanks
    If you read the info on rockauto it gives you the dimensions of the rad
    Proliance Manufacturer Info
    PRJ Built enough said!!!!
    www.prjperformance.com
  10. #10 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    GT Level Member RooK's Avatar
    Apr 2008
    Southern KY
    Just go to any parts store and ask for a radiator for a '98 Monte w/ 3.8. It's 1 3/8" thick and it's what I'm running. With my discount at AutoZone, I picked mine up for $200 otd and a lifetime warranty. Plus, they stock it in the store.
    FWIW, my car never goes above 190* on the temp gauge, it's amazing at keeping the engine running cool.
  11. #11 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Moore, Oklahoma
    Quote Originally Posted by RooK View Post
    For real? I wonder why no one had this info before? What year Grand Prix do you drive (assuming its GP)? I will definatly look into that info! Bolt in with no mods? Tranny lines fit? Cool level sensor fit? Thanks!
    Shawn W. Larsen
  12. #12 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Apr 2008
    Southern KY
    '00 GP SE (L67/HD swap). The tranny lines were fine, I think I just had to swap over the quick connect fittings from the stock 5/8" radiator. The radiator fan bracket works with minor bending. The radiator brackets work fine, since the endcaps are the same size. The coolant sensor gets mounted on the side instead of the front, and the lower radiator hose points slightly inward. None of those were issues though. Pics for those curious.
  13. #13 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Moore, Oklahoma
    Interesting, That crooked lower radiator hose neck on the bottom, does that interfer with the A/C compressor at all? Also that fill neck appears to be taller than the stock radiator, any hood interferance? Mount up like stock? Got pics of it installed?
    Thanks!
    Shawn W. Larsen
  14. #14 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Apr 2008
    Southern KY
    I don't have any install pics, but nothing interferes. This is the exact radiator that WBS sells (look at the pics on their site) and I think it's the same for ZZP as well.
    The only issue is restricted access to the coolant level sensor since it's back in a hole now and the battery is slightly more difficult to remove thanks to the neck projecting more inward.
    '13 Stang - V6 MT82 - GHIG
    '00 Grand Prix SE - Pink (L67 Swapped/XP Cam/3.25")
    '98 Grand Prix GTP - Black ($500 toy with broken trans. )
    '01 Bonneville SE - Sitting on a hillside needing attention
  15. #15 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Moore, Oklahoma
    Thanks for the info, I ordered one this evening! Did you notice that much more cooling with this rad? Just curious...
    Shawn W. Larsen
  16. #16 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    Apr 2008
    Southern KY
    Well, the car never goes over 190* (and actually has never hit it). The downside is in the winter it takes longer to heat up. I've driven the 10miles from work to home late at night in the winter and it's not hot enough to leave my fans running when I turn the car off.
    Very efficient compared to my stock 5/8" core.
  17. #17 Re: ZZP oversized radiator, link to the cheaper ones on Ebay?
    tried looking for the part number rook posted on rockauto, what is it?
  1. Intercooler radiator
    By silvermistGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 12:29 PM
  2. If you recently bought an aftermarket radiator from ZZP or W-Body store
    By Gandalf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 11:06 AM
  3. Transmission lines to radiator
    By SyntheticShield in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-25-2008, 10:45 PM
  4. New Posts Link
    By hydro1110 in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 04:23 PM
