Thread: What pulley size with these mods?
Results 1 to 11 of 11
  1. #1 What pulley size with these mods?
    SE Level Member rah575554eg's Avatar
    Apr 2009
    Alliance, NE
    I have a ported blower, ported LIM, ported throttle body, headers, TR8 NGK's, K&N air intake, high flow exhaust, 180* stat and Overkill PCM. I just wanna know what pulley would be fine to run with these mods? I want to run a 3.25" but I don't how well that would go over. Thanks!
  2. #2 Re: What pulley size with these mods?
    You can run a 3.25" It just won't run very long. Go read the Safely Modding your 3800 thread. Then ask. I'd say a 3.4" but you never know until you scan it.
  3. #3 Re: What pulley size with these mods?
  4. #4 Re: What pulley size with these mods?
    Warbeaver does...he knows EVERYTHING.
  5. #5 Re: What pulley size with these mods?
    GT Level Member skidoojames151's Avatar
    seattle
    i wouldnt go 3.25 until intercooled...a 3.4 sounds good for yor setup though
  6. #6 Re: What pulley size with these mods?
    Quote Originally Posted by skidoojames151 View Post
    I ran a 3.25" without methanol or an IC...actually a 3.0" for that matter until the injectors started to run static. Intercooler ISN'T required to run smaller pulleys
  7. #7 Re: What pulley size with these mods?
    seattle
    yes but he isnt cammed either or rockered...3.4
  8. #8 Re: What pulley size with these mods?
    Right, I'm just talking about your intercooler quote. It wasn't correct...that's all.
  9. #9 Re: What pulley size with these mods?
    Aug 2008
    Long Island, New York
    yea just add some rockers to the list then id say run a 3.4, scan and tune and see if you have no knock. Then drop to the 3.25 and see what you can do.
  10. #10 Re: What pulley size with these mods?
    May 2008
    staten island,NY
    i say machine the snout a run a 2.55, it has a high flow exhaust you know
  11. #11 Re: What pulley size with these mods?
    Why a 2.55"? That's lame just wrap the belt around the snout.
  1. pulley size
    By hollis1 in forum Introductions/Noob Questions
    Last Post: 12-16-2009, 12:14 PM
  2. need some help with pulley size
    By mack1212 in forum General Tech Discussion
    Last Post: 04-01-2009, 08:11 AM
  3. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  4. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  5. pulley size=hp?
    By underpressure2004 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:03 PM
