Thread: Straight answer on Seafoam
Results 1 to 7 of 7
  1. #1 Straight answer on Seafoam
    Virginia
    Howdy folks. I just picked up my new (to me, obviously) 2000 GTP last night. I have Seafoamed all of my cars when I purchase them, and then again at regular 1 year intervals. I've done some searching on the forums, but can't seem to find a consensus on the forums about Seafoaming our 3.8 S/C engines. I see some posts saying to use the brake booster (this is what I have always used on my other cars), some say to use a vac line into the S/C and yet others say not to use it on the S/C engines at all. So, what's the word?
  2. #2 Re: Straight answer on Seafoam
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Anything that gets the Seamfoam into the engine is fine. I have done the vacuum lines before, but have better results pouring it into the throttle body. It is just as safe on these engines as any other.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Straight answer on Seafoam
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by JoshMcMadMac View Post
    And the coating on the rotors of the blower just doesn't matter?
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: Straight answer on Seafoam
    Charles City, IA
    Seafoam will not take the coating off the rotors. And every vac line on top to the supercharger goes in the same hole to the same spot.
    SMGPFC Two Nipple General
  5. #5 Re: Straight answer on Seafoam
    QCA, IA
    Some people say it will, others say it won't. Why not just use the port below the blower and avoid it all together?
  6. #6 Re: Straight answer on Seafoam
    Jul 2008
    sumter,south carolina
    i foamed mine through the brake booster vac line... my rotors were fine when i did an engine swap a few months later. from what i understand the brake booster line is the only one that goes to all 6 cylinders.
    02 GTP with mods 05 GP for DD
  7. #7 Re: Straight answer on Seafoam
    Feb 2010
    abbotsford .b.c.
    seafoamed my 2000 last month better milage,,
  1. Can You Answer This
    By BillDee22 in forum General Tech Discussion
    Last Post: 09-04-2009, 03:37 PM
  2. noob to car audio set me straight
    By 02blackgpgt in forum Audio, Security & Visual Electronics
    Last Post: 05-30-2009, 11:04 PM
  3. Supercharger - So let me get this straight...
    By RAZOR Z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2009, 11:05 PM
  4. Straight Pipes on GTP?
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-28-2008, 08:12 PM
