Thread: Crank, but no start
Results 1 to 3 of 3
  1. #1 Crank, but no start
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    2000 GTP, stopped working randomly today. I replaced the crank and cam position sensors a few months ago. The fuel pump resistor is bypassed. Plenty of fuel in the tank. Well maintained in general.
    I commute about 35 miles to work, about 45 minutes. Half way to work, 25 minutes or so, the car "hiccuped" once. I was cruising at about 65MPH, the car was fully warmed up, and it simply felt like it lost transmission engagement for a moment. It went the rest of the way to work without a hitch. When I got in the car to go home 9 hours later, it will not start. It will crank no different than usual, but it never kicks over and starts.
    Any ideas?
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  2. #2 Re: Crank, but no start
    How long as the resistor BEEN bypassed? Since doing the resistor mod I am assuming you have the fuel pump set in high-mode...if not disregard the rest of this. I had a local that did that and a few months later high fuel pump took a sh!t...he even tried replacing the fuses for the pump too...nothing worked. His did that exact thing too..."hiccuped" ONCE, then took a dump...wouldn't run.
    Other than that...I'd look at the spark side or fuel side then...can you hear the pump priming on start? Have you tried yanking a plug wire and holding it to the strut tower to see if you are getting an arc of spark? Just a couple things...IMO...could be a bad ground somewhere too...maybe on the starter?
  3. #3 Re: Crank, but no start
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    sounds like you have a bad fuel pump
  1. Sluggish crank
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-14-2009, 02:21 PM
  2. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
  3. HELP! Cranks then Don't Crank
    By Bigboy49251 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2009, 03:25 PM
  4. HELP-car wont start/crank
    By fst in forum General Tech Discussion
    Last Post: 12-25-2008, 06:06 PM
