Thread: I have full boost now.
Results 1 to 20 of 20
  1. #1 I have full boost now.
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Ok, so i just finished up my alcohol install, and finally started driving my car again. The car has no alcohol running to it at the moment since i don't have the controller wired to a 12v ign source yet. Everything else is wired and installed. So i go today to drive my car and was missing the feeling of putting my foot into it after not driving it for 3 weeks. I put my foot into it and got one bar on the DIC boost gauge at partial and all the way up to full throttle. Then on the way home tonight i did the same thing and have zero boost at all.
    The car feels just as strong as it does with the gauge showing full. No idling issues whatsoever, and the BBV seems to open and shut like it should and not stick. I did however tap into the B (green) connector on the MAP sensor for a MAP input on my alcohol controller. I don't know if that has anything to do with anything seeing as how the alky kit isnt actually powered on at all yet. I've ran over the vac lines quickly for leaks, but will further inspect tomorrow. I'm just puzzled. It seems to run just as strong, but maybe I havent driven it in so long that i cant tell.
    Suggestions?
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  2. #2 Re: Factory Boost Guage reads Zero boost....
    get a real boost gauge and that one will no longer matter. spend the $40 for something that is a great help to diagnosing problems.
  3. #3 Re: Factory Boost Guage reads Zero boost....
    MO
    I know I need a real boost gauge, but i just dont have the money for one right now. I tried the whole disconnect the lower vac line on the BBV and let it suck air and it gave me one bar of boost again, but still no dice. Did the MAP splicing cause a problem? I wouldnt think it would. I checked every t-fitting and elbow for disconnections and found none. The car as I said still runs fine, and the pcm hasnt thrown a code for anything. So i'm out of ideas...
  4. #4 Re: Factory Boost Guage reads Zero boost....
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    i may not know much on this issue but from reading my guess would revolve around a vacuum leak of some kind. bio and others have experince in this area(one day ==me too).i know when imessed up the vacuum hose that goes to firewall and over by the fuse box,finally going under it, my gauge didn't work. anyway good luck -i'm suscribed to this thread.
  5. #5 Re: Factory Boost Guage reads Zero boost....
    MO
    Quote Originally Posted by badbrad View Post
    Ill have to check every line tomorrow and let everyone know. If not then im out of ideas, lol.
  6. #6 Re: Factory Boost Guage reads Zero boost....
    Get a cheapo sunpro gauge then...come get one from the zone
  7. #7 Re: Factory Boost Guage reads Zero boost....
    MO
    While i'm at it i'll get some fender vents and a chrome gas door sticker
    Idk, i might pick one up from there or O'reilly cheap.
  8. #8 Re: Factory Boost Guage reads Zero boost....
    Banned - Busted For Scamming
    Feb 2009
    I have a sunpro and for $25 you cant beat it.
  9. #9 Re: Factory Boost Guage reads Zero boost....
    i also think its a vacuum leak somewhere because you shouldnt have to take the line off the BBV since yours functions correctly.
  10. #10 Re: Factory Boost Guage reads Zero boost....
    MO
    Well I looked it over again today, still no dice. I'll pick up some carb cleaner and spray around and see if i get any changes in idle. If not there i'll pick up a cheap boost gauge and go from there.
  11. #11 Re: Factory Boost Guage reads Zero boost....
    You did just install the meth injection...did you use a TB spacer? If so I'd check to see if you put the gasket on the right way...
  12. #12 Re: Factory Boost Guage reads Zero boost....
    MO
    I'm almost positive I did, would it cause that much loss?
  13. #13 Re: Factory Boost Guage reads Zero boost....
    Very much so...either that is your issue or the BBV is shot like I told ya...
  14. #14 Re: Factory Boost Guage reads Zero boost....
    MO
    I did the BBV disconnect trick and it did nothing. I did notice my DIC lights flickering on the left side, but i don't think it has anything to do with it, the lego bricks still light up. I bought a boost gauge today, but the vac hose provided is too big, i'll have to get some that will fit it and let you know.
  15. #15 Re: Factory Boost Guage reads Zero boost....
    MO
    Well I think I have found the culprit, maybe. I hooked up my new boost gauge real quick to see what I was getting. I'm getting 20 inHg at idle, and around 3-4 psi boost revving in park. Upon further inspection I took off the vac line running from the T under the supercharger snout that runs to the MAP and found a needle size hole and a chip out of the line. I blew into the line and found that air was able to escape. And upon even further inspection, where the line fits into the T under the snout is nearly snapped into two. So i'm hoping I can get new lines see what happens.
  16. #16 Re: I have full boost now.
    MO
    I fixed it. It had always been something lurking in my mind as to what was the problem. I had to tap into the map sensor connector for my alcohol controller. I used the positaps provided with the kit. But instead of the positap scoring the surface of the wire and successfully tapping the source, the positap went right through the map wire leaving ZERO connection to the sensor. I took the alcohol wire off along with the "POS"itap and did the good ol fashion strip and twist until I buy some heat shrink connectors. Now I get full boost..... end of story. Thanks for all the suggestions and help!
  17. #17 Re: I have full boost now.
    Topeka, KS
    Quote Originally Posted by Lsick7 View Post
    No kiddin eh... I was going to order some posi taps. I think i might just stick with some wire connectors like this.
    Sure alot cheaper and probably less failure.
  18. #18 Re: I have full boost now.
    Donating Users blowfishRus6's Avatar
    g.a.
    as far as the vacume hoses being cracked, i just wraped mine up real tight in some electrical tape. has worked thus far.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  19. #19 Re: I have full boost now.
    im an electrical engineering and i still use wire nuts everywhere unless im soldering.
  20. #20 Re: I have full boost now.
    Feb 2009
    Wire nuts are great but you dont always have that kind of room. Then there is the whole heat shrink problem.
  1. aftermarket boost guage?
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-23-2010, 05:42 PM
  2. Boost gauge reads zero
    By COEBAM in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:44 AM
  3. installing a boost guage
    By L KELLS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2010, 09:50 AM
  4. Most Accurate Boost Guage?
    By RNUOVR in forum Off Topic Discussion
    Last Post: 01-07-2008, 03:38 PM
