Thread: Changing idle pully
Results 1 to 5 of 5
  1. #1 Changing idle pully
    SE Level Member gahris's Avatar
    Ottawa
    The belt tensioner, the one right below the alternator is making a ton of squeeking sounds. Anyone have any tech tips on how to change it, or any write ups?
    If i have to bring it to a shop, there telling me that its better to change the whole assembly, which is 120$, and the pully is just $20
    Current Car: 2006 Grand Prix GT
    Prevous Car: 1995 Monte Carlo LS
  2. #2 Re: Changing idle pully
    Donating Users blowfishRus6's Avatar
    g.a.
    yea, turn the bolt to the right (its oppesite thread) and take the bolt off, the pulley will then slide off, then reverse processes......................................... ..........
    have you looked at it yet????
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Changing idle pully
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    pretty simple process, only hiccup would be it's reverse thread as mentioned above
    For all your 3800 needs:
  4. #4 Re: Changing idle pully
    Ottawa
    i know its this pully because if I take a prybar and mput pressure on the bolt, the squeek stops.
    So that bolt that doesn't turn, has reverse threads and that it? The shop mentioned to me it would be a good idea for the whole assembly?
  5. #5 Re: Changing idle pully
    g.a.
    yea, that bolt that is not losening for you, is reverse thread.
    simple turn it the other way, then the pulley will slide off. if a new pulley does not stop the squeak THEN get a new assembly.
    and if that new assembly comes with a new pulley, well then you can use that other good/fresh/spins like new pulley for the supercharger idler pulley
    its slow.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. pully
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2009, 04:11 AM
  3. Pully
    By offroadfury6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2008, 11:58 AM
  4. Pully
    By 40thgtp in forum General Tech Discussion
    Last Post: 03-24-2008, 07:42 PM
