For all u 3800 smart guys, how and what is the simplest way if there is one to figuring out if preload is correct on my lifters? I had the motor going with my XPZ for a little bit before i had to pull it from the ARP studs leaking coolant and was hearing a tick. Im trying to rule things out that might have also been causing that. But the lifters are a likely possibility of that as well so i wanna make sure that is in spec and can rule that out.
Most of u know of my build and that it has zero miles yet and about 30 minutes of run time. The motor is out again currently. The LIM is off along with the valve covers so the lifter valley and rockers are exposed.
Thanks
