where does this vac line go to... im geting all kinds of codes and car is running like ****... TPS code, MAF code, fuel trim too lean code.
Those numbers sound fine.
99-03 should work fine, both L36 and L67. 97-98 were different.
LOL, I typed my reply, my internet went down, and in the mean time you completely changed your post. Nothing goes on that port, it's left open.
I had the same question a few days ago and searched around and also made a post about the same connector and it's supposed to be opened like that. It only used to have some kind of foam filter around it from factory. If you block it, you the bbv won't open completely and won't get full boost.
