Thread: which worn parts to replace at almost 90k miles?
Results 1 to 18 of 18
  1. #1 which worn parts to replace at almost 90k miles?
    GTP Level Member
    Nov 2008
    MA
    im gonna start buying new parts to help the life of the motor..with almost 90k on the motor what preventative maint. would you do? fuel pump? radiator? how about replacing stock wp with a Meziere EWP?
    and which parts hurt the motor when they break? replacing these parts are my priority next
    thanks guys
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  2. #2 Re: which worn parts to replace at almost 90k miles?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    fuel filter, good oil, new spark plugs, some seafoam, change supercharger oil, fluid flush(anti freeze, trans, power steering)
    what year you driving?
  3. #3 Re: which worn parts to replace at almost 90k miles?
    new struts.
    check all suspension bushings and joints.
  4. #4 Re: which worn parts to replace at almost 90k miles?
    who cares? 90k miles is nothing. drive it until something actually breaks or you break it from putting to much power through it.
  5. #5 Re: which worn parts to replace at almost 90k miles?
    Cedar Rapids, IA
    i know 90k is nothing but he wanted something so i gave it to him
  6. #6 Re: which worn parts to replace at almost 90k miles?
    change your oil and make sure your dexcool hasnt gone sludgy.
  7. #7 Re: which worn parts to replace at almost 90k miles?
    Donating Users kfish's Avatar
    Ohio
    if it aint broke dont fix it.
  8. #8 Re: which worn parts to replace at almost 90k miles?
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    I would get rid of the Dexcool. Flush it all out really good and use regular green coolant!
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  9. #9 Re: which worn parts to replace at almost 90k miles?
    SE Level Member 2001GTP's Avatar
    Apr 2009
    Phoenix, AZ
    Quote Originally Posted by GTPcoupe View Post
    Use the green coolant that mixes with either the green or the dex cool.
    3.6", 3" Downpipe, K&N CAI, 104's, PRJ Tune, P-Log, 180 t-stat,Res delete, wideband, boost gauge. 14.11" @ 99.5
  10. #10 Re: which worn parts to replace at almost 90k miles?
    Quote Originally Posted by 2001GTP View Post
    That'd be yellow...
  11. #11 Re: which worn parts to replace at almost 90k miles?
    GTX Level Member cerick08GP's Avatar
    thanks guys
    Well, like others have said, first thing is to flush out the Dexcool and use green coolant. #2 Change spark plugs #3 New front O2 sensor
    Also consider, as TurboTrav mentioned, putting a can of SeaFoam in your gas. SeaFoam it is awesome stuff and best used as a preventative measure. I highly recommend doing this as step #1.5
    And an oil change very 5K, as always.
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  12. #12 Re: which worn parts to replace at almost 90k miles?
    Jersey
    i like my water pump, dexcool works just fine, just keep it fresh. Yellow is basically the same as dexcool.
    16' wrx sti- stock
  13. #13 Re: which worn parts to replace at almost 90k miles?
    Ohio
    im running green with no probs.
  14. #14 Re: which worn parts to replace at almost 90k miles?
    Quote Originally Posted by kfish View Post
    i ran straight old school green too, but i had my motor apart enough that i never actually did a real flush on my car and it was all green and no sludge.
  15. #15 Re: which worn parts to replace at almost 90k miles?
    Charles City, IA
    I am going green when I put my engine back in. LOL never thought I would say that.
    SMGPFC Two Nipple General
  16. #16 Re: which worn parts to replace at almost 90k miles?
    Ohio
    LOL me too. no sludge in there at all. took a hose to the water jackets with the knock sensors out actually.
  17. #17 Re: which worn parts to replace at almost 90k miles?
    Canada
    just do your normal maintenance. my car has over 300k and i have int done much more then that and it runs great. fix it when you know it need to be done.
  18. #18 Re: which worn parts to replace at almost 90k miles?
    GTP Level Member
    Nov 2008
    MA
    my GTP is an 03'..thanks for the responses all
    99 GTP - DD
  1. What tools and parts are needed to replace the LIM gasket on the S/C 3800 motor?
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2009, 09:46 AM
  2. How to add adjustment to worn rear struts
    By fuzzydog1 in forum Brakes/Suspension/Chassis
    Last Post: 07-03-2009, 05:41 PM
  3. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  4. what do i need to replace
    By guy87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-27-2009, 07:30 PM
  5. would hi-mileage/worn spark plugs cause KR at WOT/PE?
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2008, 08:15 AM
