Thread: on my way modding
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 on my way modding
    pennsylvania
    well i bought tr6 ngk plugs, i bout 3.4 pulley, ordering downpipe in two weeks bought zzp 1.0pcm, oil change royal purple and some lucas, supercharger oil change elbow replacement new thermostat, After reading the how to mod 3800 thread i think i will be good with smaller pulley also getting the aeroforce gauge what should be my next mod to help roller rockers or cams?
  2. #2 Re: on my way modding
    GT Level Member RamonGTX's Avatar
    menasha wisconsin
    headers?
    Polished Gen V, 3.1 mps, intercooled, S1X cam, northstar tb, and Tim King built trans with 3.29s and all the good stuff
  3. #3 Re: on my way modding
    Banned
    CT
    What are your goals with the car? With the price of headers so cheap these days that should be first priority. ZZP downpipe and ZZP tune are a big waste of money. I'd cancel the order ASAP.
  4. #4 Re: on my way modding
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Send a PM to Reptile (GPF member) and he will hook you up with a good tune for cheap.
    +1 for Headers.
    Get all that put on, then worry about what's next.
    You will like, you will see.
  5. #5 Re: on my way modding
    pennsylvania
    so the downpipe is not worth it. should i just fix the ubend problem? the zzp pcm doesnt help? i didnt pay full price for it
  6. #6 Re: on my way modding
    Dec 2010
    Canada
    Quote Originally Posted by jspangler22 View Post
    Do you put a hamburger on a bun, or do you put bacon, cheese, tomatoes and other tasty chit with it to triple its goodness?
  7. #7 Re: on my way modding
    pennsylvania
    What
  8. #8 Re: on my way modding
    Banned
    CT
    What
    Cancel the downpipe and don't bother with the ubend delete... get headers.
  9. #9 Re: on my way modding
    pennsylvania
    yea i just went on to ebay just to get an idea and seen headers come with everything i need how easy is the header install im going to go that route will getting these headers delete my cat because all the pipes dont lok like a place for cat to go
  10. #10 Re: on my way modding
    pennsylvania
    now after i go with the header set up what should i do about an exhaust i want to get something a little louder should i just get cherry bombs and just replace mufflers because my resanator still seems in good shape
  11. #11 Re: on my way modding
    Jul 2008
    Tampa, FL
    there are a few header threads. the search button is your friend. as far as exhaust, stick with the stock catback. trust me...
  12. #12 Re: on my way modding
    Jul 2008
    Tampa, FL
    btw, i can tell that you have not read much around here. no one, and i mean no one recommends a zzp pcm. unless your goal is chipped pistons...
  13. #13 Re: on my way modding
    pennsylvania
    well the one guy is selling me on here saying it was a good pcm so i just went for it. I know on the 3800 mod thread it said they werent to good my mistake so if i get these headers and another pcm i should be okay with running the 3.4 after reading the 3800 mod thread either way i need to keep eye on my kr. I did search for header install but it just gave me threads of people asking which headers to get.
  14. #14 Re: on my way modding
    Waukesha, WI
    billboost has the install thread
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  15. #15 Re: on my way modding
    Jul 2008
    Tampa, FL
    Quote Originally Posted by redlinepontiac View Post
    yeah, that's probably the best install thread...those speed daddy's are the way to go for real...
  16. #16 Re: on my way modding
    Waukesha, WI
    you cant beat 205 shipped
    RayRay
    92 Turbo miata
    02 lexus is300
  17. #17 Re: on my way modding
    GTX Level Member real diehl's Avatar
    Salina, KS
    I wouldn't get cams. You'd be buying **** you don't need. Your car has a cam, as in a singular cam...
    signature removed for inappropriate content.
    -bio
  18. #18 Re: on my way modding
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Get a dyno tune!
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  19. #19 Re: on my way modding
    GT Level Member GtpKo's Avatar
    Best place on Earth
    I put Speed Daddys on last month. Not hard really just a PITA to get the old dp off. Old manifolds came off easy. Follow Bill's thread it's detailed enough for a modding noob like me.
    Also look into buying a tiny C5 or Alero O2 sensor (at least 1/2" shorter), they have long leads so you don't need an extention but you'll have to splice in a female connector on the wiring harness.
    In-car tune > dyno tune > canned tune. I'm hoping to get one of these w/ a 3.5 next week.
    And they're right about the whole mod bug thing
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  20. #20 Re: on my way modding
    Waukesha, WI
    the alero sensor works too?
    RayRay
    92 Turbo miata
    02 lexus is300
  1. help with modding
    By sdenton8 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2011, 11:02 PM
  2. Further Modding My GTP. Suggestions?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2010, 01:11 PM
  3. Modding 08 GP GT..
    By 08GrandPrixV6 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2009, 09:57 PM
  4. Modding my GTP
    By NewPrixOwner666 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 08:26 PM
  5. modding my gtp
    By scottys99gtp in forum Off Topic Discussion
    Last Post: 02-25-2009, 04:48 PM
