Thread: carb cleaner + blower rotors= FAIL
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 carb cleaner + blower rotors= FAIL
    Jul 2008
    sumter,south carolina
    cleaned my throttle body really good and overspray got on my rotors.
    02 GTP with mods 05 GP for DD
  2. #2 Re: carb cleaner + blower rotors= FAIL
    Wooster, Ohio
    hmmm, not sure how bad that is...i know the coating is like a lubricator basically, i know abrasive knows a ton about m90's so he may know if theres something you could recoat em with
  3. #3 Re: carb cleaner + blower rotors= FAIL
    Charles City, IA
    You will not make much boost at all with those. Just find a set of good used ones and replace them.
    SMGPFC Two Nipple General
  4. #4 Re: carb cleaner + blower rotors= FAIL
    Jul 2008
    either that or i might have mine recoated... whichever is cheaper. anyone have a good set that they can part with?
  5. #5 Re: carb cleaner + blower rotors= FAIL
    Portland Oregon
    Dude, it even says in your owners manual to not spray anything in there that ha methyl etheyl keytones in it. Basically carb cleaner.
  6. #6 Re: carb cleaner + blower rotors= FAIL
    Jul 2008
    Quote Originally Posted by OH4CompG View Post
    live and learn... didnt have throttle body cleaner.
  7. #7 Re: carb cleaner + blower rotors= FAIL
    Portland Oregon
    Yea, I was impressed when I saw that in the owners book. I just pulled the tb to clean mine. Oh well, I think there's a guy on here that epoxy coats the blower rotors. He'll hook you up
  8. #8 Re: carb cleaner + blower rotors= FAIL
    Banned - Busted For Scamming
    Feb 2009
    Well i know you can clean with brake clean so im not sure about carb cleaner. I dont use the stuff ever cause it doesnt ever dry correctly.
  9. #9 Re: carb cleaner + blower rotors= FAIL
    prove it. carb cleaner didnt do that. those rotors are old.
  10. #10 Re: carb cleaner + blower rotors= FAIL
    GTX Level Member real diehl's Avatar
    Salina, KS
    Good news is it appears you have 76 cents to put towards a new set.
    signature removed for inappropriate content.
    -bio
  11. #11 Re: carb cleaner + blower rotors= FAIL
    Feb 2009
    I already sold him a set so yea.
  12. #12 Re: carb cleaner + blower rotors= FAIL
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    ^^^^ uuhhh, thats how i took the coating off of my rotors...therefore-PROOF...getting them was gonna be more expensive, it was cheaper just to buy another s/c cheaply from ebay. . so thats what i did..and yes carb. cleaner will and does remove the coating.
  13. #13 Re: carb cleaner + blower rotors= FAIL
    Quote Originally Posted by badbrad View Post
    prove it. take a perfect set and run a little carb cleaner through it. i bet it does not touch the coating. i ran meth through my perfect rotors for quite a while and it did absolutely nothing.
  14. #14 Re: carb cleaner + blower rotors= FAIL
    Feb 2009
    I just sold him a set for $20 so how is that cheaper?
  15. #15 Re: carb cleaner + blower rotors= FAIL
    Dec 2008
    hueytown, alabama
    ^^obviously..i wish i had contacted u before i got a s/c from ebay.. wasn't a total loss, i ported the case,and sold old case and rotors. but yeah, great deal for him.
  16. #16 Re: carb cleaner + blower rotors= FAIL
    Jul 2008
    the rotors were fine until sprayed the throttle body down, after i sprayed it and cleaned out throttle body.. i looked at rotors and the coating was literally bubbling off... i ran my finger across it and it was mush. keep in mind i peeled alot of it off after i realized they were ****ed.
    Quote Originally Posted by realdiehl View Post
    lmao, good observation skills. got bud to smoke on too.
  17. #17 Re: carb cleaner + blower rotors= FAIL
    Dec 2008
    hueytown, alabama
    "prove it"??? are u serious? i had the rotor pack out gently sprayed the off when i was cleaning out the case.. just because u think u know all doesn;t really mean much to some. ur advice and insight is very helpful alot of times. then other times u sound like a jerk-because YOU haven't seen it. i don't know, maybe u just come off acting like a jerk, but maybe ur not.
  18. #18 Re: carb cleaner + blower rotors= FAIL
    Feb 2009
    Still have those junk rotors?
  19. #19 Re: carb cleaner + blower rotors= FAIL
    Dec 2008
    hueytown, alabama
    no i do not. i sold them along with another spare case and a fac. size pulley. then i bought another spare motor that i'm rebuilding-therefore 1 spare s/c. its a gen 3 but it'll be good to have a spare. if i do ever try to sell , i'd let u know. i do not have much in it.
  20. #20 Re: carb cleaner + blower rotors= FAIL
    the coating wont come off with spraying it with anything. the coating only chips off on its own. its not even anything that would just wipe off with a spray. youd have to scrape at it. you wiped it down to a chrome/polished look with just carb spray and a rag? how is carb spray with alcohol any different from methanol?
  1. SLP intake for l67 come with a carb sticker
    By 01gtprocket in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-19-2009, 10:43 PM
  2. Engine Cleaner
    By JCG's-GTP in forum Detailing Tips and Tricks
    Last Post: 08-12-2009, 04:37 PM
  3. Spray brake cleaner all under the engine?
    By Greinerts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-09-2009, 07:54 PM
  4. just when i thought it couldnt get any cleaner...
    By kyle99gtp in forum Visual/Body Modifications
    Last Post: 08-16-2008, 12:06 AM
  5. any ideas on stainless tip cleaner?
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 07-30-2008, 11:05 AM
