Thread: Ported LIM, cut gasket to match?
Results 1 to 16 of 16
  1. #1 Ported LIM, cut gasket to match?
    Friendswood, TX
    I'm installing a machined LIM since I'm in there fixing a coolant leak. I have a Felpro plenum gasket which obviously has the openings to match the OEM LIM. Have most of you cut the gasket to match the machine LIM?
  2. #2 Re: Ported LIM, cut gasket to match?
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    yes sir, thats right.
  3. #3 Re: Ported LIM, cut gasket to match?
    See above^
    Just curious why you bothered to have your LIM machined.
    If you have stock heads and you don't have an intercooler its kinda pointless : \
  4. #4 Re: Ported LIM, cut gasket to match?
    Friendswood, TX
    I plan on adding an intercooler later and rather than pull up the LIM twice, I did the machined LIM now. Baby steps, I guess.
  5. #5 Re: Ported LIM, cut gasket to match?
    Dec 2008
    hueytown, alabama
    matt i've heard some folks machine down the divider in the lik,,i have no clue if it helps..i'd do it for when i intercool.
  6. #6 Re: Ported LIM, cut gasket to match?
    Fair enough.
    Isn't the divider not that tall at all? if so, i'd leave it, it just helps redirect the flow of air.
  7. #7 Re: Ported LIM, cut gasket to match?
    Dec 2008
    hueytown, alabama
    ??? i know zzp sells their lim with divider cut out as well as the s/c section opened up, i'd rather doit myself and gasket match/port the runners. my o.p. of course
  8. #8 Re: Ported LIM, cut gasket to match?
    Banned - Busted For Scamming
    Feb 2009
    Dont cut out the divider in the lim, that hurts flow.
  9. #9 Re: Ported LIM, cut gasket to match?
    Dec 2008
    hueytown, alabama
    i have wondered about that, but thats zzp, i just don't know about their credibility sometimes.
  10. #10 Re: Ported LIM, cut gasket to match?
    Anyone have pics for comparison?
    This goes back to the intake mani discussion all the old school guys have.
    divided or open.
    Generally if you're running really high in the engine speed, go for open.
    But our engines make no power up there so its best to leave it on that assumption.
  11. #11 Re: Ported LIM, cut gasket to match?
    Feb 2009
    Huh, i thought we were talking about the little air divider in the bottom of the lim, why would anyone take that out?
  12. #12 Re: Ported LIM, cut gasket to match?
    we are.
    In high performance small blocks and big blocks, the IM's they run typically do not have a divider yet the all time classic, Edelbrock Performer does since its not for high revving engines.
    Edelbrock.com - Manifolds - Chevy
    Look at the associated RPM ranges.
  13. #13 Re: Ported LIM, cut gasket to match?
    Feb 2009
    This isnt even the same type of divider nor the same type of engine. The lim divider is not even a restriction period so why would you do that. You are actually hurting it because the air that would ramp off of it shooting towards the runners are now unable to do that. It just makes no sense period.
  14. #14 Re: Ported LIM, cut gasket to match?
    Lets see...both undersquare, both OHV.... I realize there are many other differences, but theres not much you can do to overcomplicate an intake manifold short of having more than one runner (which would have been a good idea...)
    I agree with what you're saying because if you check out the RPM ranges for the undivided IM's, its 3000-8000... far from the powerband of these engines.
  15. #15 Re: Ported LIM, cut gasket to match?
    Feb 2009
    The manifold runners arent divided to begin with so i dont see what you are saying. The manifold you showed has a completely different design to begin with.
  16. #16 Re: Ported LIM, cut gasket to match?
    You're completely missing the point.
    I'll just drop it.
  1. HUD and cluster speedometer don't match
    By Maitiu in forum General Tech Discussion
    Last Post: 02-26-2009, 03:14 AM
  2. Can't get timing to match table values!??!
    By DanGTP in forum PCM Tuning
    Last Post: 10-25-2008, 11:45 PM
  3. Michigan Grudge Match
    By Anthony Shaw in forum Shows and Events
    Last Post: 09-07-2008, 09:07 PM
  4. Color match or Carbonfiber
    By JCG's-GTP in forum Visual/Body Modifications
    Last Post: 03-27-2008, 11:43 AM
  5. Painting interior parts to match car
    By 99BluGP in forum Visual/Body Modifications
    Last Post: 02-17-2008, 07:35 PM
