Thread: Car disabled due to theft system AFTER ZZ PCM installed
Results 1 to 13 of 13
  1. #1 Car disabled due to theft system AFTER ZZ PCM installed
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    pluged computer and went to start and nothing.. then that message poped up.. what the hell is that!? HELP!!! Thanks
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  2. #2 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    I put my PCM back in and started fine wtf....
  3. #3 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Barksdale AFB, LA
    The new PCM has to learn the security system in your car. It's called a Security Relearn. Your old PCM still remembers so of course it works.
    1.) Turn the car to on, then attempt to start. Car will not start.
    2.) Note security light flashing. Wait approximately ten minutes. Light stops flashing.
    3.) Turn ignition to off. Wait five seconds.
    4.) Repeat steps 1-3 two more times, for a total of 30 minutes.
    5.) The PCM is now ready to learn the security system on the next crank. Turn the car to off, then try to start. Car will start.
    2009 Subaru Impreza WRX STI
  4. #4 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    Sabre if this works I will love you forever... this has frustrated me lol
  5. #5 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Barksdale AFB, LA
    Quote Originally Posted by JCG's-GTP View Post
    I just did it yesterday on my Impala. Should work.
  6. #6 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    My light isn't flashing but i'm trying it anyways. New message poped up "Theft security system not set" or something similar
  7. #7 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Barksdale AFB, LA
    It may not be exact, and that's what I was worried about. What happened with mine was the message center alternated the "Security" message with the "battery" icon. After ten minutes, it was only the battery icon.
    YMMV.
  8. #8 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    Do i leave door open and key in ignition?
  9. #9 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Barksdale AFB, LA
    You don't have to. I just sat in it and listened to music while I waited.
  10. #10 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    Didnt work
  11. #11 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    Its Alive!!!!!!!!!!!!!!!!!!!!!!!!!!
  12. #12 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Feb 2008
    Nashville
    Sabre TYVM. That was probably the easiest but most frustrating thing I have done lol. BTW love the new PCM
  13. #13 Re: Car disabled due to theft system AFTER ZZ PCM installed
    Barksdale AFB, LA
    I'm glad you figured it out. I was pretty sure the basic procedure was similar since our cars are so similar.
  1. HELD Coilovers Installed!!
    By JashGTP in forum Visual/Body Modifications
    Last Post: 05-17-2008, 12:46 AM
  2. WBodyStore Grilles Installed!
    By x1FastGTPx in forum Visual/Body Modifications
    Last Post: 03-15-2008, 04:06 PM
  3. Catalytic Converter Theft
    Last Post: 02-24-2008, 09:49 PM
  4. Just installed wizaired CAI
    By 3800SE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-17-2008, 07:46 PM
  5. SLP Header Installed
    By J_Ferguson in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2008, 03:02 PM
