Thread: Best Performing and looking cold air intake?
Page 5 of 5 FirstFirst ... 345
Results 81 to 88 of 88
  1. #81 Re: Best Performing and looking cold air intake?
    GTP Level Member David99GTP's Avatar
    Florida
    Quote Originally Posted by IndeedSS View Post
    The Impala guys are lucky then. The Wizaired pulls air from the fenderwell and there is a huge gap behind our headlight its gets air from as well. It's like having a fWI w/o having to put the filter all the way down in the fender.
    Its the same on our cars.
    Not sure what is being refered to as air only being pulled from the headlights. I actually took my cutoff tool on my compressor and cut excess metal to make the fenderwell access larger to the wizaired box that mates up with it. So even if my headlight area isnt allowing much airflow, the dang hole to my fender will allow all the air it can suck. Hole is 3x the size of the filter.
    I like the FWI because the airbox takes up so much room. I have thought of switching for appearance reasons only.
    But I do have to say this whole CAI topic is
    There are a few good options, and everyone is going to back what they believe. My advice take the info and make a choice based on what you think makes sense.
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  2. #82 Re: Best Performing and looking cold air intake?
    Moore, Oklahoma
    That design is the same on the GPs too.
    As for the comment I said eariler. I never said "air only being pulled from the headlights", I said "The Wizaired has no air coming unless the headlight is removed", as in there ain't steady airflow being pushing into the CAI box when the car is moving. Sure air is being pulled in behind the headlight and the Fenderwell, every CAI on the market does that. But unless you headlight is removed, you ain't getting a steady air flow into the CAI box. The lid is below the radiator support so air coming through the hood gap is going into the engine bay and the box ain't catching any of it. Thats what I was saying.
    All the CAI options out there are good, choose what you want. You can't go wrong. Although I would recommend saving some $$$ and buying a used setup and modding it to you liking (thermal barriers, etc), There for sale all the time on ClubGP, I picked up my GFs Thrasher CAI dirt cheap off there. When I have time, i'll do a few thermal mods to it and it'll perform real nice. Granted I bought my CAI new and got good use out of it, nowadays I would just recommend picking up a good used one honestly. HTH...
    Shawn W. Larsen
  3. #83 Re: Best Performing and looking cold air intake?
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    My vote is with open cone, I see MAF readings well above 10khz! The more air the better, and I get no KR at WOT ever.
    My mods are XP/W Body store IC/2.8/N*/Ported SC/Ported Heads/Togs/Open Cone
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  4. #84 Re: Best Performing and looking cold air intake?
    Odessa, MO
    LOL!
    As far as looks go, I am super happy with the JMB. I imagine it performs just as good as any other FWI, even a homemade one. My only real complaint with the JMB is it has absolutely no give and tends to work itself loose from the throttlebody from the normal engine movement. This happens now matter how tight I make it since it's rubber connection to the TB is so short. I'm half tempted to cut it down a bit and try a longer rubber coupler. Also, not much I can do with it if I switch to an LS1 or N* later down the road. It would have to be cut significantly to allow the placement of the MAF for either of those TB swaps.
  5. #85 Re: Best Performing and looking cold air intake?
    Oklahoma
    Where do I find clamps like that?
  6. #86 Re: Best Performing and looking cold air intake?
    Odessa, MO
    I've got a message in to Swash about where he got them. He put the intake on before I bought the car. I assumed they came with the intake, but I could be wrong. I'll let you know when I find out.
  7. #87 Re: Best Performing and looking cold air intake?
    Barksdale AFB, LA
    Quote Originally Posted by t24moore View Post
    W Body store IC
    That's why.
    Non-intercooled cars sucking such heated air would be a different story.
    2009 Subaru Impreza WRX STI
  8. #88 Re: Best Performing and looking cold air intake?
    TDCRacing
    Guest
    Quote Originally Posted by Abrasive View Post
    they didnt come with the intake i just bought a jbm and it just came with regular clamps....
    i just tightend the heck out of the clamps and it has not come off for me....also do not use the rubber piece that they give you for the throttlebody...just leave it off...helps it grip better when it goes in the groove in the throttlebody.....but then again i just bought solid polly upper mounts too...that also helps i guess
  1. making a cheap cold air intake ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-17-2010, 04:10 PM
  2. Making a cheap cold air intake [*]
    By nvsridez in forum How To Write-Ups/Tech Tips
    Last Post: 11-05-2009, 10:10 PM
  3. Cold Air Intake
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 02:25 PM
  4. Why is it this cold in Texas? (LR Pics)
    Last Post: 03-08-2008, 02:54 PM
  5. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
