Thread: header leak
Results 1 to 20 of 21
  1. #1 header leak
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    ok so i have pacesetter headers and i know they are known to leak. but i was wondering if there is any way to stop the leak other than welding them? thanks.
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: header leak
    RTV is your friend
  3. #3 Re: header leak
    Grayslake
    the copper one right?
  4. #4 Re: header leak
    No...High Temp Red.
  5. #5 Re: header leak
    Grayslake
    alright thanks
  6. #6 Re: header leak
    Charles City, IA
    Copper is better than the high temp red. That red stuff is the worst kind of RTV it is not sensor safe and it is corrosive. That is coming from a permitex rep that I talked to.
    SMGPFC Two Nipple General
  7. #7 Re: header leak
    Worked for me and still does...not sure why the rep would say that but w/e. I've never had an issue with it as MANY members here I know for a fact.
  8. #8 Re: header leak
    SE Level Member BlackGS's Avatar
    Central Jersey
    No RTV will last very long on headers. I have tested everything, including JB Weld, and the only decent sealant is Manley 907 high-temp epoxy. But even that did not hold permanently.
    There are two problem spots on Pacesetters, the y-pipe joints and the triangular flange. The y-pipe joints pull apart from engine movement, so the only permanent fix is to weld at least one side. The flange can be epoxied, but the better solution is to either weld it after the headers are installed on the car, or grind down the flange and install a v-clamp.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  9. #9 Re: header leak
    Just suck it up and weld them. Then you don't have to worry about it...ever.
    http://www.grandprixforums.net/f73/l...ion-16085.html
  10. #10 Re: header leak
    Banned - Busted For Scamming
    Feb 2009
    Who doesnt own a welder, honestly? Lol
  11. #11 Re: header leak
    GT Level Member tylerbinski's Avatar
    Canada
    I used exhaust cement.. was like 1.99 at canadian tire.
    worked well
  12. #12 Re: header leak
    Grayslake
    i would like to just weld them but no one around here will do it. and the people that say the will charge over a $100
  13. #13 Re: header leak
    Wausau, WI
    you will probably use a hundred dollars in RTV if you dont weld them........LOL
  14. #14 Re: header leak
    Quote Originally Posted by grand2000prixgtp View Post
    Not sure why...it is just like welding exhaust pipe...get them installed and drive it over there with open DP/Crossover and tell them to weld it up...should only need two welds...now way that costs a hundred bucks...mine ran me like 40. Then when they charge you, kick them...leave 40 bucks and drive off. Not like they'll catch you anyways
  15. #15 Re: header leak
    Indiana
    where do the headers need welded at? also my ssac headers tic. why do they do this. some say its the downpipe. is it? how can i fix it?
  16. #16 Re: header leak
    SSAC's are not the same as pacesetters... different design.
  17. #17 Re: header leak
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    weld=ftw......sounds like a good time to learn!!!!!!!!!!ssac????i have no clue...
  18. #18 Re: header leak
    Charles City, IA
    I didnt weld my ssac's and they dont leak.
  19. #19 Re: header leak
    Topeka, KS
    Nor do mine. I've heard its the Flex That ticks. I dunno i have had mine for a week and they do not make any noises except for out the tailpipe.
  20. #20 Re: header leak
    ^^And this guy beats the living god out of it too
  1. SLP header fitment
    By 01goldgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2009, 07:08 PM
  2. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  3. spilling oil on header
    By crshoveride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 06:56 PM
  4. ARP Header bolts
    By Sabrewings in forum General Tech Discussion
    Last Post: 07-29-2008, 01:57 PM
  5. TOG Header Question...
    By Iron Indian in forum General Tech Discussion
    Last Post: 01-09-2008, 01:00 AM
