Thread: SSAC Headers
Results 1 to 20 of 20
  1. #1 SSAC Headers
    Indiana
    I have ssac headers on my 2002 gtp. i am wondering if they need to be welded in any places? also they tick above 2500rpms. i was wondering what this is. some say it is the flex pipe on the dp. is this it? if so how do i fix it?
  2. #2 Re: SSAC Headers
    Wooster, Ohio
    i know from everyone who has them they don't need welded. Can you not have someone run the engine up while you listen under the hood? Also the old paper trick always works, just hold a small piece all around the seal points and if it starts moving theres air flowing
  3. #3 Re: SSAC Headers
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    Chances are, that's exactly what it is. Pick up one from ZZP and have it welded in
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  4. #4 Re: SSAC Headers
    Donating Users kfish's Avatar
    Ohio
    check where the crossover pipe goes into the rear header. mine leaked there.
  5. #5 Re: SSAC Headers
    Nov 2008
    ohio
    Do you need stainless wire to weld the flex pipe in the headers on a mig welder?
    04 Grand Prix GTP (Wizaired, 3 inch downpipe)
  6. #6 Re: SSAC Headers
    Tofu Delivery Boy Lsick7's Avatar
    MO
    Quote Originally Posted by kfish View Post
    Same here, also, check the where the EGR and the rear header meets and see if that's not the culprit.
    Gold Digger - still broke, lawn ornament
    05 M6 PBM GTO - Corsa exhaust, aem intake, bmr drag bags. More whenever I haz monies
  7. #7 Re: SSAC Headers
    Both of those spots were cured up on Rynoman2K3's car with a nice bunch of copper RTV. No leaks...period
  8. #8 Re: SSAC Headers
    Nov 2008
    I used RTV and Torq-tie band clamps on my crossover so I haven't had a single issue with leaks. Which is why I threw out the idea of it maybe being the flexpipe... Which is known to ting
  9. #9 Re: SSAC Headers
    Topeka, KS
    We used the clamps that came with the headers and RTV'd the **** out of everything. No Leaks after romping on it all week either. I just gotta get the sway bar flipped. GMPP Sway Bar FTL.
    FWIW my SSACs do not tick either. Maybe you have a leak ?
  10. #10 Re: SSAC Headers
    Nov 2008
    Me? Mine doesn't. I'm just saying that it IS a common issue and if you do hear any ticking or whistling noises, chances are that's where it's coming from. A leak would be heard right away, it's not like a vacuum leak where you have to try and find a source. Leak in the crossover, even a small one will make it sound almost open headered. Especially under load
  11. #11 Re: SSAC Headers
    Ohio
    not true. you couldnt tell mine leaked till i was on the highway with the cruise set at 70. start it up and it idled quiet. i never had a clamp at the rear header for the cross over though haha
  12. #12 Re: SSAC Headers
    ^^Well thats the reason ya friggen noob. It needs a clamp every place it slids in.
  13. #13 Re: SSAC Headers
    Nov 2008
    x2 :P
  14. #14 Re: SSAC Headers
    CT
    HA HA HA HA HA HA this should be stickied lol.
  15. #15 Re: SSAC Headers
    Ohio
    well i couldnt get to it to clamp it! this last time i clamped the cross over to the rear header and put it all in as one piece
  16. #16 Re: SSAC Headers
    Indiana
    I wrapped my flex pipe with header wrap and it quieted the tick a bunch. but not enough.. its still there. If i get a zzp flex pipe, could i cut the other one out and weld it in to the DP? do you think it would get rid of the tick?
  17. #17 Re: SSAC Headers
    Ohio
    yes and yes
  18. #18 Re: SSAC Headers
    Indiana
    alright i'll be doing that this weekend then. thank you
  19. #19 Re: SSAC Headers
    Topeka, KS
    I believe that you want to TIG it though being that it's stainless. I could be mistaken though.
  20. #20 Re: SSAC Headers
    Indiana
    what is the best way to get to the flexpipe. will i have to remove the rear headers to get to it or could i cut it out and weld it in while still on the car
  1. where can i buy ssac headers?
    By Joe m in forum Shops and Community Heroes
    Last Post: 01-07-2010, 07:15 AM
  2. SSAC Headers
    By xringshooter7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-01-2009, 12:26 AM
  3. SSAC Headers
    By kfish in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2009, 04:47 PM
  4. SSAC or Pacesetter Headers
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2009, 09:31 AM
  5. XS Power Headers Vs. SSAC Headers
    By 04CompG in forum General Tech Discussion
    Last Post: 12-02-2008, 01:12 PM
