Thread: Cleaning S/C
Results 1 to 5 of 5
  1. #1 Cleaning S/C
    GT Level Member Xorbex's Avatar
    Canada
    I have these http://www.4mailers.com/Images/Produ...es/3734_xl.jpg
    to clean the outside of my S/C is that a good idea? There seems to be a bit of corrosion on her.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  2. #2 Re: Cleaning S/C
    should work fine, but a wire wheel would work better. they are cast aluminum, so they dont exactly look the nicest to begin with.
  3. #3 Re: Cleaning S/C
    Canada
    Yes its cast alum. The super is on the car and its outside in a freeking parking lot so im just gonna try the scotch and see what happens. Just trying to keep myself occupied.
  4. #4 Re: Cleaning S/C
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    well, not being a smart a$$, but the s/c case will tear up them there scotch brite pads.....u must be real bored..
  5. #5 Re: Cleaning S/C
    SE Level Member vsl67's Avatar
    Australia
    you would be better of using a steel scourer ,steel wool ,tooth brushes ,paint brushes with carb cleaner and turps or kerosene this is what I used to clean my motor down with before I started to detail it ,the turps or kero wont hurt paint but be careful with the carb cleaner And Dont use degreeser it doenst work very well and doesnt like paint ,and just gently rinse with water or carefuly pressure wash the motor afterwards
  1. cleaning up the outside
    By crshoveride in forum General Tech Discussion
    Last Post: 06-03-2011, 09:09 AM
  2. cleaning headers?
    By 05SS45 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2009, 04:50 AM
  3. s/c cleaning?
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2009, 09:39 AM
  4. sensor cleaning
    By stanwich in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2008, 09:11 PM
  5. cleaning a sub
    By MTXGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2008, 01:53 PM
