Thread: 2000 GT NON-SC Vacuum Diagram anyone?
Results 1 to 10 of 10
  1. #1 2000 GT NON-SC Vacuum Diagram anyone?
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Just like the title says...
    I need a diagram for my 3800 NA motor that I dropped into a different car. My ltft's are pegged @ 16.4 so it's either a leak that I can't find, or something is missing
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Massachusetts
    wrong sub forum...
    move around the engine with a can of brake cleaner and keep spraying until you hear the engine rev up a few hundred RPM's. WHen you do, thats your leak.
    2003 GS
  3. #3 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Oct 2012
    New Jersey
    Went through 2 large cans of carb cleaner... No rpm change.
  4. #4 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Massachusetts
    what did you recently change? LIM gasket? TB gasket? replace injectors? They have the potential to cause vac leaks...
    2003 GS
  5. #5 Re: 2000 GT NON-SC Vacuum Diagram anyone?
  6. #6 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Oct 2012
    New Jersey
    Thank you sir.
  7. #7 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Oct 2012
    New Jersey
    Well, after installing a few new vacuum t's, my ltft's at idle are between 1-2. The instant I go 10% throttle or more, the ltft's shoot to 25 and the car runs line hell...
    What I've checked so far:
    -Vac leaks... No vac leak.
    -Replaced MAF - Same issue
    -Replaced both 02 sensors - Same issue
    -New AC Delco plugs installed with all new ign wires - Same issue
    Any ideas??
    This engine is completely stock. All I did was move it from one car to another, no mods at all!
  8. #8 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Did you check the check valve at the brake booster?
    did you remove the EGR tube and check that?
  9. #9 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    Oct 2012
    New Jersey
    There's a check valve there? I take it you mean in the vacuum system somewhere?
  10. #10 Re: 2000 GT NON-SC Vacuum Diagram anyone?
    the hose that connects to the brake booster. that swivel piece that sits into the hose and booster..it's a check valve.
  1. Vacuum diagram for top swap
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2012, 02:51 PM
  2. Need a vacuum diagram for this car ..
    By turboLude in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-25-2012, 06:22 PM
  3. Replies: 0
    Last Post: 07-19-2012, 07:16 PM
  4. In need of some diagram help please!!!!
    By 97gtpfreak in forum General Tech Discussion
    Last Post: 07-10-2012, 07:20 AM
  5. 2000 grand prix GTP vacuum lines
    By MikeGabyrs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 11:34 PM
