Thread: Silicone baking sheet as a blower gasket
Results 1 to 20 of 37
  1. #1 Silicone baking sheet as a blower gasket
    Donating Users kfish's Avatar
    Ohio
    i read somewhere that someone did this for their intercooler to seal. just wondering if there were any side effects to it or not. im working on a home port job on my blower, and i figured this would make a great reusable gasket. also any suggestions on porting? i got a good idea of where i wanna go, along with filling the silencer ports.
  2. #2 Re: Silicone baking sheet as a blower gasket
    Banned
    oswego
    Quote Originally Posted by kfish View Post
    Dude for real, after all the work of putting everything together you're going to risk it by putting a piece of baking material between it?
    Get a gasket dude, i'm sure bob at SDD can help you out. Shoot him an email to Robert@SinisterDD.com or visit their website at Sinister Drag Designs - Chicagolands new performance specialist! I'm sure he'll agree that baking sheets aren't going to "cut" it (LOL i crack my a$$ up)
  3. #3 Re: Silicone baking sheet as a blower gasket
    Ohio
    um, its been done before, i dont see the issue. but im not going that route anyways. i thought id still have my original gasket to use as a pattern, but it got all ripped up. so im just gonna but a sc and tb gasket tomorrow.
  4. #4 Re: Silicone baking sheet as a blower gasket
    Banned
    oswego
    Well then, baking is your thing, go for it! When you post up a thread about weird idle issues and vacuum leaks i'll go ahead and link this thread. As you said, get an sc/tb gasket, don't do this whether it's been done before or not, it's not a good idea, period.
  5. #5 Re: Silicone baking sheet as a blower gasket
    Apr 2009
    stockton ca
    Not on any ones side here but if the silicone sheet could stand the heat and was torqued properly I honestly dont see any leaking probles
    Once again not choosing sides just dont see why it wouldnt work
  6. #6 Re: Silicone baking sheet as a blower gasket
    Portland Oregon
    Just thought I'd chime in and say that silicone gaskets do work. There's a guy that lives in Chandler AZ that I know personally that installed a Gen V with a stage 3 ZZP intercooler and proceeded to run 12's all day in 90 plus degree weather and no vacuum leaks with home made silicone gaskets.
  7. #7 Re: Silicone baking sheet as a blower gasket
    Ohio
    yea no ****! but you cant tell this guy anything. hes always right. o well ill just go buy a gasket
  8. #8 Re: Silicone baking sheet as a blower gasket
    Donating Users blowfishRus6's Avatar
    g.a.
    if someone said they were gonna sell me baked silcone gaskets at a parts store i might just go to another store.
    seeing as how people have said it has worked well okay. would i still kinda dought it, yea. what if when it bakes up the gasket deforms some and your left with a not so stock gaskets.
    would i try it, maybe, would i use a **** load of rtv with it, **** yea.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #9 Re: Silicone baking sheet as a blower gasket
    Ohio
    hopefully the parts store has my gaskets i need. i got the blower ported last night
  10. #10 Re: Silicone baking sheet as a blower gasket
    g.a.
    if they dont gm dealer does. napa always had a supercharger gasket at there store when i called about it.
    its slow.
  11. #11 Re: Silicone baking sheet as a blower gasket
    Banned - Busted For Scamming
    Feb 2009
    Yea i run a silicone gasket. It has been brought up before and i tried to bring it up at club gp and was laughed at. Go figure.
  12. #12 Re: Silicone baking sheet as a blower gasket
    Ohio
    seems like a great way to make a reuseable gasket to me. but what do i know.
  13. #13 Re: Silicone baking sheet as a blower gasket
    Feb 2008
    San Diego, CA
    I'm doing silicone sheet gaskets:
    Along with some other Bonneville guys:
    BonnevillePRO.com • View topic - Silicone sheet to make reuseable s/c / IC / LIM gaskets?
    Not using a baking sheet, but rather some silicone sheet material:
    Silicone Rubber Roll and Sheet for Gaskets
    As long as the baking sheet is somewhat smooth (no deep "pattern" molded in) and is large enough (minimum 11" by 15") I would assume you'd be OK.
  14. #14 Re: Silicone baking sheet as a blower gasket
    Feb 2009
    Yea it is. But i agree with agrazela, i bought it on ebay as a large sheet and its thinner mainly, the ones you buy at the store are kinda thick.
  15. #15 Re: Silicone baking sheet as a blower gasket
    Ohio
    i wasnt aware you could buy it like that. well alright! no issues with it?
  16. #16 Re: Silicone baking sheet as a blower gasket
    Feb 2009
    No. I run a baking sheet on my dd everyday. And trust me, i RUN it lol.
  17. #17 Re: Silicone baking sheet as a blower gasket
  18. #18 Re: Silicone baking sheet as a blower gasket
    i always used the stock GM gasket.
    I'm with this guy
  19. #19 Re: Silicone baking sheet as a blower gasket
    Feb 2009
    You could. It just gets pricey when you take off the blower alot and have to buy a new gasket each time. You can make a reusable silicone one for $10.
  20. #20 Re: Silicone baking sheet as a blower gasket
    UNLESS...you don't run it that often and all your coolant passages are closed on the LIM...I've re-used a few blowers gaskets with no issues.
  1. Gasket Help??
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2009, 02:21 PM
  2. silicone gasket need help quick...
    Last Post: 09-01-2009, 07:24 PM
  3. Oil Pan Gasket
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2009, 10:03 PM
  4. Carbon Fiber sheet?
    By robahr24 in forum General Tech Discussion
    Last Post: 08-24-2008, 04:39 PM
