Thread: Temp gauge
Results 1 to 11 of 11
  1. #1 Temp gauge
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Where does yours sit when the engine is fully warmed? Mine appears to be at about the 170-175 range. I bought an OEM t-stat to correct the situation, but haven't put it in yet. A buddy of mine has an '02 GT and said he didn't see the gauge move much from there when he installed one in his (also OEM).
  2. #2 Re: Temp gauge
    Jersey
    is it a 210* or a 180* t-stat?
    16' wrx sti- stock
  3. #3 Re: Temp gauge
    Apr 2009
    I assume the OEM is a 195 - no idea what is in there now. It's either too cold, stuck open or the sensor is bad.
  4. #4 Re: Temp gauge
    Jersey
    oops, yeah it is a 195* i dunno where i got 210 from. how many degrees is it outside? My temp dosen't go much above 160 range, even though its really at 180* according to aeroforce and its around 35* out around here
    16' wrx sti- stock
  5. #5 Re: Temp gauge
    Apr 2009
    Ambient is about 31, but it was cool this summer, the last time I drove it also. All our other vehicles run right up at near the 200 mark, as they should. I'll try to change out the t-stat over this coming weekend to see if that brings the temperature up. Is there a bleed procedure on these, too, like my '93 with the 3.1?
  6. #6 Re: Temp gauge
    Jersey
    Quote Originally Posted by SnowDrift View Post
    yeah, u have to bleed it, you let it warm up, then you loosen the nut on the t-stat housing, and let it run until it bleeds a steady flow of coolant.
    16' wrx sti- stock
  7. #7 Re: Temp gauge
  8. #8 Re: Temp gauge
    Apr 2009
    the gauge starts at 160*. rethink where it is.
    Not sure what you're saying. It starts at 160 and the only other number is 210, which gives me exactly 50 degrees from indicator number to indicator number. 210-160=50. Assuming it's equally divided on each of the marks between those numbers, that puts the needle at about the 170-175 mark when the engine is fully warm.
    Perhaps your dash reads differently than mine?
  9. #9 Re: Temp gauge
    PA
    Not on my 97!
    But you can't trust the temp gauge on the dash. Mine usually rides around 170° on the gauge. But my scanner shows it 185-195°. So they are not really that accurate. If you really are interested, get a scanner or better temp gauge.
    2001 GSE
  10. #10 Re: Temp gauge
    mine always ran at the first major notch, which read about 185-190* on my scanner. i had a 180* thermostat. the heat worked great.
  11. #11 Re: Temp gauge
    SE Level Member bensett004's Avatar
    michigan
    same with mine.....even on cold days it stays at the first notch and heat will burn u out
    fwi, kn filter, 3 in down pipe, power log, 180* thermostat, 10000k hids and soon to come a dhp pcm
  1. 2005 Grand Prix - temp gauge/cooling fan issues.
    By lateralus20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2011, 12:46 AM
  2. Temp Gauge stopped working???
    By GXP05er in forum 5.3L V8 (LS4)
    Last Post: 08-10-2010, 07:37 PM
  3. temp on aeroforce and temp on dash
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 01:05 PM
  4. Outside temp gauge on climate control
    By 99prixgt in forum General Tech Discussion
    Last Post: 10-05-2008, 05:13 PM
