Thread: grinding noise in reverse
Results 1 to 3 of 3
  1. #1 grinding noise in reverse
    edmonton
    Just started today ....there is a gring noise when my 03 gtp in reverse...any ideas...is this a common issue?
    thanks
  2. #2 Re: grinding noise in reverse
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    did you just have a 3" dp installed today?
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  3. #3 Re: grinding noise in reverse
    Feb 2010
    USA
    hey my brakes are doing the same thin on my 07 grand prix GT if you find anything out or vice versa pls post
  1. Pulley making metal grinding noise??
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-14-2010, 10:46 PM
  2. Right-Front Grinding Noise
    By cowmilker08 in forum General Tech Discussion
    Last Post: 06-07-2010, 01:36 PM
  3. SuperCharger Grinding?
    By Sameer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2009, 07:57 PM
  4. Grinding Sound
    By Strype in forum General Tech Discussion
    Last Post: 09-02-2009, 01:15 PM
  5. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
