Thread: swap to a non sc engine?
Results 1 to 7 of 7
  1. #1 swap to a non sc engine?
    Dec 2008
    indiana
    i have a gtp and blew the motor a ouple weeks ago. i was wondering what i would have to do(and if its a good idea) to swap in a 3800 out of a gp gt. i want to do it because of the higher compression. i also have a 3.4 pulley, xp cam, heads up are ported, 3in dp. would it be too much stress? and i heard the non sc 3800 have the timing advanced 1 degree stock? what do i do about that?
  2. #2 Re: swap to a non sc engine?
    Lemme guess, you blew the front bank of pistons?
    well you'd need the heads up assembly with a few other parts, see the top swap thread and get headers.
  3. #3 Re: swap to a non sc engine?
    Dec 2008
    indiana
    no. i spun a rod bearing, cam bearing slide out halfway and got all chewed up, and the main bearings are washed out. i have a l67 motor. i wanted to bottom swap it for the higher compression.
  4. #4 Re: swap to a non sc engine?
    you can use an l36 block. the higher compression will allow you to more easily blow up the motor when you introduce boost. if it doesnt knock, it is just as strong as the l67. you would time it at 0 and it would run fine. it is not really advanced anymore after you take the timing set off and replace it.
    done.
  5. #5 Re: swap to a non sc engine?
    Dec 2008
    indiana
    done.
    yeah thats the only thing i was worried about, blowin it up. im at almost 10lbs of boost now with a 3.4 pulley so.
  6. #6 Re: swap to a non sc engine?
    Quote Originally Posted by projectGTP View Post
    Wow that sucks
    Get headers and make sure its not knocking.
  7. #7 Re: swap to a non sc engine?
    I've got a full L36 bottom end with 88K on it sitting here. PM Me.
  1. Doing an Engine Swap
    By XxJNUGExX in forum Engine
    Last Post: 09-26-2009, 01:29 PM
  2. engine swap
    By nfloyd2006 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-09-2009, 11:00 PM
  3. Engine swap?
    By Spacedonut in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-24-2009, 02:01 PM
  4. L36 engine swap
    By themagicdustman in forum General Tech Discussion
    Last Post: 02-05-2009, 07:08 AM
  5. engine swap
    By 3800John in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-03-2008, 02:53 PM
