Thread: Finally got to drive my car today
Results 1 to 5 of 5
Preotic Finally got to drive my car... 03-12-2008, 11:15 PM
nemesis Re: Finally got to drive my... 03-13-2008, 02:08 AM
Preotic Re: Finally got to drive my... 03-13-2008, 05:50 PM
silvermistGT Re: Finally got to drive my... 03-13-2008, 10:59 PM
Reptile Re: Finally got to drive my... 03-19-2008, 12:57 PM
  1. #1 Finally got to drive my car today
    GT Level Member Preotic's Avatar
    Missoula, MT
    After fixing my belt alignment problem i took the car for a spin. I haven't driven the car since 0ct 30 07. This winter I ported the heads, 3 angle valve job, .052 MLS gasket, arp head studs, gen v swap, n *, LQ4 and a 3.4. After letting the fuel trims learn i went WOT. 7 lbs of boost, 0 KR and fuel trims locked in at 0. I'm really happy with the work i put in. This is all on a xp tune that i bought from zzp. I will tune it eventually but for the first run i was suprised. I suppose only pushing 7lbs of boost helped but thats good for a 3.4 on a Gen v.
    L26,Xp, zzp trans,3.29's,2700 conv, slp headers/catback, diy ported heads/LIM, 3 angle valve job,.052 MLS hg, outlet ported Gen V, 3.6, N*, LQ4, 4" FWI, agx's, ssc's, f-bodys, gmpp sway's +stb's
  2. #2 Re: Finally got to drive my car today
    chicago
    7lbs of boost, is that kind of low for your mods?
  3. #3 Re: Finally got to drive my car today
    Missoula, MT
    I'm assuming it's only pushing 7lbs of boost because it flows well.
  4. #4 Re: Finally got to drive my car today
    Ossian, IN
    This is just from what I've read. But the XP bleeds off a lot of boost, IIRC, you should be able to run a lower pulley. But you are right in starting higher and working down from there once you are sure that with some tuning it will run good. I'm ready to drive my car again!
  5. #5 Re: Finally got to drive my car today
    Bastard Reptile's Avatar
    Kansas City, MO
    It sounds about right. Good head flow will actually show lower boost levels...but that's a good thing. It just means that it's more efficient. Timing adjustments or even a 3.2 might really bring things to life.
    I'm working on a set of heads for mine, I run a 3.2 on it now with about 10lbs of boost, and no KR. Can't wait to see what she does with heads and a 3.0.....or maybe a new engine all together!
  1. Drive Belt Idler Pulley Replacement [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-20-2014, 05:07 PM
  2. Drive Belt Replacement [*]
    Last Post: 05-24-2009, 05:44 PM
  3. Possible to change drive/driven sprockets in-car?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2008, 03:18 PM
  4. Changing internal gearing? (not final drive)
    By Ron Vogel in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2008, 02:27 AM
  5. Drive Belt Tensioner Replacement [*]
    Last Post: 01-03-2008, 10:54 PM
