Thread: Loud whistling noise
Results 1 to 13 of 13
  1. #1 Loud whistling noise
    At idle after the car warms up I can hear a loud whistle coming from the EGR area. The car actually feels a little bit more sluggish. I am not sure what is goin on but could my EGR be going bad? Or maybe theres a leak in the EGR?
  2. #2 Re: Loud whistling noise
    Oklahoma
    Typically, a whistling noise would indicate some type of vacuum leak, possibly from the vacuum line that connects to the EGR.
  3. #3 Re: Loud whistling noise
    Banned
    New Port Richey Florida
    Check the metal egr tube running from the bottom of the erg mounting plate to the rear manifold
  4. #4 Re: Loud whistling noise
    Barksdale AFB, LA
    Idle air controllers whistle when dirty.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Loud whistling noise
    Saraland Alabama
    is there a vaccuum line ? Mines electronic. If it was the tube underneath it sounds like an exhaust leak (just fixed mine) pcv valve is close to that area, as is brake booster line
  6. #6 Re: Loud whistling noise
    Oklahoma
    Quote Originally Posted by archemedes View Post
    You are right archemedes, I completely forgot ours are electronic. I was under the hood on my Isuzu over the weekend and looked at the EGR there and its vacuum operated. Egg on m face I guess. What makes it worse is I have a spare EGR and was looking at it over the weekend too. Geesh.
  7. #7 Re: Loud whistling noise
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by Minno View Post
    Are you the Minno I know? With the HPTuners? If so, you can use the VCM controls in the scanner to command the EGR open and closed. This may help you determine if it is EGR related.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  8. #8 Re: Loud whistling noise
    GT Level Member stkks's Avatar
    Annandale, Virginia
    Now I am not sure, but I get only a whistle when it is really cold outside. And I have been told that it could just be the supercharger. But I am not for sure on that one. My whistle only happens when the car first starts up and then it stops after a few seconds.
    Autopage Alarm w/Remote Start-35% Tint-SPO Tips/Grills-GMPP RTAs-F/R STBs w/Don's brackets-SilverStars H/L Beam-DHP PCM-CORSA-Thrasher CAI-Class II Receiver Hitch-AVS Vent Visors/Tailshades-Chrome Side/Engine Supports-180T-stat-3 AeroForce Gauges-MSD Coils/Wires-NGK TR-55IX
  9. #9 Re: Loud whistling noise
    Saraland Alabama
    bearing maybe going out, and the heat spreads lube again?
  10. #10 Re: Loud whistling noise
    Oklahoma
    Well my GTP was doing that before it went up on Jack stands. I had a new blower pulley on there and had put on an oversized idler pulley so barring a problem with one of the tensioner pulleys, it would most likely be the alternator.
    Im wanting to paint my alternator, so I'll probably be looking for a spare soon anyway so I'll be able to rule that out.
  11. #11 Re: Loud whistling noise
    Yes Lee its Dan Anywho this problem has gotten worse as I haven't had time to look into it. When I give the car maybe half throttle it cuts out for about 2 seconds. I am getting worried. I dont think its vacuum related although its possible because I redid all the vacuum lines. I am gonna have to fix this because I knew when the whistling noise came about that the car didn't pull as hard but now it wont even run right. Any suggestions would be awesome! Thanks.
  12. #12 Re: Loud whistling noise
    SE Level Member Talsition's Avatar
    Stevens Point, WI
    Anybody figure this out because I got it now and at first I thought it was my breaks but then when I opened my hood it was definitely under there. Just to much noise to pin point where it is coming from.
    98 Grand Prix GTP - Custom FWI, 104 autolites, 180* t-stat, TDR Fbody Break Kit
    95 Eagle Talon ESI - 2Gb Conversion, lots of mods still slow.
  13. #13 Re: Loud whistling noise
    SE Level Member burnt89's Avatar
    IL
    i had a whistle and it was a vaccum line running from the throttle body to some where by the firewall that combined with new spark plugs and wires eliminated all my problems
  1. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  2. Whats this noise? (Video)
    Last Post: 02-27-2008, 02:05 AM
